Question about Lexmark Office Equipment & Supplies
I have not used my printer for ages it is working but not printing i have tried shaking the ink cartlidges but it has not worked
  • 1,498 Answers
After long periods of non-use, ink can dryin the jets and jam them up. The clean printhead utilities that come with the printer may not work when this happens.
A couple tricks:Try pulling the cartridges and cleaning the print surface with a q-tip and alcohol. Then set it on a paper towel or newspaper for 30-40 seconds to draw the ink out. Replace them in the printer and re-try.
If this fails, heat some water up in a bowl (you don't mind getting ink on). Dip the cartridges in for a few seconds, then dry with newspaper/paper towel.. Replace in the printer and try to print.
Let me know how it goes, OK?
Posted on Aug 31, 2008
Hi havent used this printer in a while and set it up to my laptop, i tried to print and it wasnt working so i thought that it was the ink as it hadnt been used for a while so i went and bought all new...
Remove and then replace the black ink. Make sure you remove any sealing tape that may be covering holes in the ink cartidge. While the ink cartidge is removed, you might also want to give it good shake. Finally, the cartrice may juat have been too old - they age even when in the packaging, and most have an expiry date.
Nov 08, 2017 | Epson C64 InkJet Printer
Plastic ruhlatec strip broken
Hi thereThis is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 11, 2010 | Canon PIXMA MX310 All-In-One Printer
My printer wont print after i put in new ink
My printer will not print after I put in a new cartidges it is a Canon
Sep 13, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Just put in a new Cartlidge and it says left Cartlidge missing. Does not print.
try cleaning the contacts of the printer with rubbing alcohol of that doesn't work return the carterage
Jun 28, 2009 | Lexmark X6575 All-In-One InkJet Printer
Canon Pixma 9500 suddenly starts producing light prints
I'm not sure if this is possible with the 9500 (it won't be if the 9500 uses chipped cartridges)...
But have you installed the photo version of a Magenta or Cyan in the Non-phone cartridge... ie: PM instead of M, or PC instead of C.
It's a long shot as I don't know that particular models age, etc... but it's been done (by me included *blush*).
Feb 16, 2009 | Canon PIXMA Pro 9500 InkJet Photo Printer
C3180 feeding paper but not printing
I ended up unplugging the unit for a few minutes. It fixed the problem...
May 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer won't print
My printer will not print black ink. The color ink is very light. I replaced a new color cartlidge, cleaned the printheads and tried to callibrate, but the printer could not identify the callibration page from my scanner. Can you help me resolve my problem?
May 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer will not print
Down load the Epson utility from When you have installed the program double left click the task bar icon and select your printer model. New right click the icon and a control panel comes up, this enables you to reset counters and many other service tasks There is also a Forum on this site.
Apr 06, 2007 | Epson Stylus CX1500v Printer
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
