Question about Sony PlayStation Portable (PSP) Console
Sony psp problem
I was taking out a broken lcd screen when i accendentally the little square part that connects the lcd screen to the motherboard is there any way i can fix it and if i can't could you please tell me where i can get a new motherboard for a psp 1001.
  • cshende Sep 03, 2008
    how can i find someone that can fixes sony psp in my area?
    Sergeant:
  • 241 Answers
HI here this has ALL PSP parts http://store.richspsxparts.com/pspaccessories.html
PLEASE RATE MY HELP Kindofcheap
Posted on Aug 31, 2008
Ok guys (and gals)... I bought a psp 3001 on ebay dirt cheap thinking it was an easy fix. The discription said the LCD screen wouldnt turn on. i received it today and opened it to find that the psp was in...
i really can't say, i would assume there would be a website that sell spare parts for the psp, i forgot the name of the one i use to go to, i need a new lil plactic thingy for the anolog, cuz it would go in another dir, i bought it, installed it, turns out that was not the prob at all and that i needed a new anolog in all.... so i just installed a plug in to disable the anolog, but i think i remember seein parts such as lcd screen parts and stuff... i got mine from some where in the uk.. the shippin was just a lil bit more,, (like $4 or so) ...
Oct 26, 2010 | Sony PlayStation Portable (PSP) Console
Nothing on the screen when psp is switched on
Turn the PSP off and remove the battery and battery cover. Remove the two screws underneath the battery. Remove the other two screws on the opposite side of the battery. Remove the final screw on the bottom edge of the PSP.Grasp the PSP on both sides with each hand and pull the cover off of the PSP. Locate the button bar on the bottom front of the PSP. Use your flathead driver to lift up the left side of the button bar until it pops up off the LCD support. Lift the button bar cable tab upwards to remove the cable and remove the button bar.Insert your flat driver into the small space on the left side of the LCD screen between the the LCD housing and the LCD mounting bracket. Twist the screwdriver slightly and the mounting tabs will pop out. Gently remove the other side of the LCD after popping out the first side tabs. Bend the PSP screen all the way down until you can see the backside of the screen.
Lift up the flex cable connectors and unhook the cables that connect the screen to the PSP motherboard. The tabs are brownish in color; they are very fragile, so be gentle. Lift the PSP screen out of the housing and place to the side.Place your new PSP screen into the PSP, face down like you had the older screen after popping out the mounting tabs. Connect all of the cables from the PSP screen into the motherboard tabs. Fold the screen back into the bracket, snapping it into place. Place the button bar back onto the LCD support, connecting the last cable. Place the cover back onto the PSP and tighten screws to finish.
Apr 02, 2010 | Sony PlayStation Portable (PSP) Console
How to fix my psp the screen wont turn on
PSP SCREEN BROKEN, CAN IT BE REPLACED? how much will it cost?
Yes it can be replaced but its a little bit expensive otherwise there is an LCD screen made in china available in your area cause it is far more cheaper than the original one hahaha.For the cost I think 50 to 80 dollar for the original PSP LCD screen.
Jun 28, 2009 | Sony PSP (Piano Black)
Screen Problem
i think one of the problem that you have is the lcd of your psp it might be broken or the light of the lcd has a damage so i suggest that you buy a lcd for your psp.then ask the vendor if they can change the lcd i think if they are selling an lcd for the psp they can handle that. hope i help
Apr 29, 2009 | Sony PlayStation Portable (PSP) Console
Inside screen is broken
ya it can just searcch on craigslist.org "psp repair" without the quotation marks and you'll be able to fix it for like $60.00 hope i helped u dude, i just broke my screen like 2 months ago, and i got it fixed for 60 maybe u can talk to the guy about putting custom firmware for free =D
Dec 20, 2008 | Sony PlayStation Portable (PSP) Console
Green light but nothing comes on
It seems that inside your PSP the LCD Screen Connection cable (The broad One) which is connected to the motherboard is being loose contact so if you can open the PSP try it by re-fixing the cable again otherwise you better go for a technician who will do the same job for you.
Sep 10, 2008 | Sony PlayStation Portable (PSP) Console
Repairing the psp
if i was you i would take into a professional shop because you have to remove all the umd drive and motherboard to get to the lcd screen
Mar 23, 2008 | Sony PlayStation Portable (PSP) Console
PSP suddenly has vertical lines no image
For your first PSP: there is a loose conection of LCD Screen with the motherboard and the solution is as follow: You can open the PSP and just lift the LCD Screen up be sure before lifting LCD Screen one thin Switch panel of micro buttons Home,VOL,select etc, you have to remove this first then only it is possible to lift the LCD Screen and after that you check that broad connection strip which is fixed with the motherboard socket you remove it this strip and refixed it again,your problem should get solved if suppose your LCD Screen is not broken.
Sep 02, 2007 | Sony PlayStation Portable (PSP) Console
My psp screen is too dark
if the psp screen is anything like a laptop it will have a backlight that lights up the screen what can happen is you can break the light and while you will still see things on the screen when you look closely but it wont be illuminated. i had a friend that dropped his laptop and smashed the backlight he sent it away and got it fixed i suggest you send it to sony to get it fixed
Aug 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
