I jsut got and old 1979 5th wheel that has a coleman mack"EL" rv sieries rooftop air cond the guy tried to change out the motor and screwed it up and while doing so removed all lables identfiying the unit so i need a general wiring diagram from switch to fan motor for one
mine was doing the same thing. I found the plastic blower wheel was warped from years of sitting in the sun. Changed it with a new one and now my motor will last longer.
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Try calling a local appliance repair or HVAC/refrigeration contractor.
A mechanical refrigeration contractor would have a better chance of having or being able to get replacement parts faster. But you have to get someone with an HVAC knowledge to look at it.
While the R.V. mechanics may be good at simple repairs or general knowledge, you need a trained eye to look at this issue here.
I would suggest to have a tech diagnose the problem and quote to repair. If the quote sounds reasonable, then go for it (your paying for expertise and a warranty). If not, then you at least have an idea of where the problem lies and what steps needs to take place to try to get it fixed.
GO TO rvcomfort.com
GO TO rvcomfort.com
It's likely that the contacts are stuck closed. You can usually just tap them with a screw driver and they will open but then you should replace them. If you don't know where they are. Find the power wires coming inside the unit and follow them. Contacts are fairly easy to replace as long as you do it wire for wire. In other words when you remove a wire from the old attach it to the new before removing another. I hope this helps. Please don't forget to give me a Fixya rating.
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
