Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars lite 2 pool heater burner not lite
Pilot light stays on but burner underneathe won't come on. please help.
  • sa1lman Apr 24, 2009
    The pilot stays on but the burner does not come on; wires appear to be OK; water pressure appears to be fine
  • Vaughan Bastien May 20, 2013
    water and wires good
Ive got the same problem and am fitting a new thermal generator i will let you know if it works
Posted on Feb 28, 2009
  • 1,420 Answers
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Posted on Dec 05, 2008
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Can't get the pilot to stay lite after I turn the knob to the "on
sounds like a thermocouple its a metal proble looking thing nex to the pilot light with a small copper tube attached to it that goes back to the burner control.
Aug 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 pool heater burners will not ignite
millivolt readings are independent of pump and filter.just make sure heater is in off position for accurate read
Jun 17, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
677 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Craig Butler
Craig Butler
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
