Question about Linksys Wireless-G WRT54G Router
Always getting ON DEMAND status
I got ON DEMAND status for wireless network, after click CONNECT still not respond..please help me, even i know the WEP key, it is not working...
  • 97 Answers
The Device they have including Manual Instruction?
- please read carefully on how to setup and configure the router.
- Try to setup and configure again your router
Please send me the full setup of your Linksys Wireless-G device...
Posted on Sep 22, 2008
I am using tp link adapter wn650g. i have two problems 1) when i click the tp link icon on the task bar it says authenticating on the link status. 2) although i have a 108 mb card but it always connect...
Hi!
The Authenticating status means that you entered an icorrect network key. The 54Mbps is the wireless speed that your card is getting from the wireless router. That means that your router can only broadcast a maximum speed of 54Mbps. This is usual for Wireless-G routers. Although your card is capable of receiving 108 Mbps, the router doesn't have that speed. The 108 Mbps can be attained if you have a Wireless-N router. To resolve the Authenticating error, try to reconnect to your wireless network using the TP-Link utility. Make sure to enter the corrent wireless network key also called as passphrase. If you are using WEP as security mode, follow the steps below
For Win XP
1. Go to Control Panel, Network Connections
2. Right click on Wireless Network Connection > Properties
3. Click on the Wireless Network Tab and at the bottom you'll see Preferred Networks
4. Highlight the name of your network and click on Properties. Click on Authentication tab then uncheck the option that says "Enable IEEE" something like that. Click OK all the way out
5: Check if that fixes it. You may also try to reboot the computer after that.
One more thing is you can try to change the Channel of your router. You can do that by connecting your laptop hardwired to your router then access router web interface
Feb 18, 2011 | Computers & Internet
I have no problems with a wired connection but the wireless will not respond even though the connection on my laptop shows to be connected and working properly. I have renewed the DHCP and this solves the...
I suggest that you have Windows 7. If I'm wrong post me back to send you the right steps. Let's go and click on "start" - "control panel" - "view network status and task" - on the right side click on "change adapter settings".
For the Wi - Fi connection right click on "Wireless Network Connection" - "properties" - choose "Internet protocol version 4 (TCP/IP) " - "properties". In case of not at automatically settings, click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
Your screen has to be like this:
Click on OK at both windows and check for the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 18, 2010 | Linksys Wireless-G WRT54G Router
I have a wireless device in my computer which worked at my friends house, but when i come here it seems that it wont allow me to do any sort of internet related activities. By this is mean it wont even...
go to start then if its xp click run or right above the start button type in ncpa.cpl and click enter. Right click on wireless networks then click connect/disconnect. Find your network name and connect to the internet. Let me know if that doesnt work.
Sep 18, 2010 | Acer Computers & Internet
I just got a HP Pavilion dv4000 what will i need to have internet access at a motel or somewhere that it detects wireless networks I dont even know where to start the basics would be a big help thanks
In a lot of cases they are setup to find wireless signals automatically. If you are in a place with a wifi, you should see an icon in the bottom right of the screen. If you click on that it should show you what networks are available and if they are unsecured, which most motels are, you can click on "connect" and that should do it. If you go on as "public" it protects you a little better. Make sure you always update your virus software when roaming.
Nov 20, 2009 | HP Pavilion dv4000 Notebook
Right, do not know what I am doing but here goes....connected desktop pc to wireless router, then tried to do the same with my Fujitsu Amilo laptop and can't, i've gone into adminstrator command prompt...
Make sure first that you know the wireless settings on your router. Take note of the SSID (wireless network name), wireless channel, wireless security settings (WEP/WPA, preshared key/passphrase/wep key/wireless network key).
For Win XP/Win Vista: On the system tray (lower right corner of the screen; near the clock), right click on the double-monitor icon that says Wireless network connection. Then select View available wireless networks.
You should detect the SSID or wireless network name. Highlight it, then if it asks for a network key, you need to type the wireless network key. Then click connect.
Hope this helps!
Oct 22, 2009 | Computers & Internet
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
When i select my Linksys WiFi connection on my Iphone I still has the "E" edge symbol on my Status bar even though wifi is selected.
You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
Do you have problems connecting to any other wireless network with your iPhone?
Have you tried using the forget this network option on your iPhone for your wireless network followed by trying to connect to the network again, and/or using the reset network settings option on your iPhone which erases all previously saved wi-fi connections that you have successfully connected to with your iPhone?
Let me know....
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 22, 2009 | Apple iPhone 3G
Turn on wireless on my 2920
Maybe it's been disabled. Go to Start - Control Panel, Classic-View - Network connections. Then look at your Wireless Network connection status. Does it read Disabled? If so, then right click on it and enable it.
Apr 04, 2009 | Acer Aspire 7110-2069 Notebook
Mine always does that when my IP address lease renews but it's an easy fix. You can usually click on the pop up that says limited or no connectivity then in the box that comes up click repair. If you cannot get to that box you can just go to start>control panel>network connections then right click the wireless network connection then left click repair. That usually works for me.
Hope that helps!
Jill
Nov 30, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
More help needed please!!
hi, the Broadcom 802.11g Network Adapter is your built in wireless adapter. right click that then check the status if it is working properly, it would tell you that on the status, on that you will also have an option to go and update the driver of your card.
Sep 17, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
110 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
