Question about Acer Aspire L100 PC Desktop
Overheating and sporadic shutdown - does this follow screen freezes and fan stopping?
I really know nothing about computers and their dodgy sporadic behaviour but my system just stops - screen freezes, fan stops working and everything stops. After a few seconds/minutes of sitting idle (i'm not doing anything to it at all, no mouse clicking, no ctrl/alt/del-ing or even just pressing the space bar) one of two things happen....
1: The fan powers up again and computer continues to process information, the screen starts to work again, mouse icon moves and then a few minutes later it will freeze again
2: It turns itself off, no warning, no error message just off. Sudden death.
And when I restart the computer there are no error messages telling me that something has happened it just carries on as norma for a while until it reaches the point of system crash and then.... it powers off.
I have, however, looked in the setup menu (by pressing del before windows (XP if that makes a difference) loads up and check the health status of my PC and the temperature readings are within the shutdown parameters, as it says that the CPU temp is at 40deg C and the CPU shutdown isn't until it gets to 97deg C... the ambient temp, however, is at 70deg C - does this make any difference to anything? Would mounting of extra fans be advisable (if so what models, how much are they and how easy are they to attach them to the computer...)?
I am also going to download some scanning software to se if that yields any results but we shall see....
Thanks very much for any help or asdvice you can give me
    Brigadier General:
  • 5,158 Answers
I would suggest you have the fans/heat sinks cleaned as soon as you can. it is most likely shutting down because of heat (thermal shutdown). on some laptops the fan doesn't come on till close to melt down (my inspiron laptop is great for that). If you are at uncomfortable with taking the bottom of the laptop off to clean out the dust and dirt from the fan take it to a shop and have it done.
you may want to invest in one of those laptop chillers... basically a stand with fans on it. they make usb ones that get there power from the usb connection. abit ruff on the battery if you are not using a/c but better then replacing the cpu.
Robert
Please rate my solution thanks
Posted on Sep 02, 2008
Frozen screen when hot
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Most of the time, PC starts running slow and freezing by lots of reasons. Corrupt registry, unnecessary applications, as well as too many start-up items would be the major reasons contributing to this problem. Many PC users simply utilize PC yet never consider how to maintain and optimize PC performance. I would suggest you to download any reliable program to fix registry, to manage unnecessary applications & start-up items like am using Reginout since 2011. Many programs are available in market which can perform these steps, but don't believe on free products. Now its up to you. :-)
Good Luck.
Nov 12, 2013 | Dell Latitude E6510 Laptop
My computer will shutdown autimatically within 5 minutes
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Dec 05, 2012 | Asrock ConRoe1333-D667 Motherboard
MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP...
If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
But, if the Computer shuts down randomly, it is due to the Processor.
All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan in the Computer should resolve the issue.
Jul 05, 2010 | Computers & Internet
Computer heat problem?
what you need is a (laptop pad with fan,)
Aug 14, 2009 | Computers & Internet
Shutdown Issues
It could be overheating, either you need to replace the fan, or at least open it up and remove any dust (bunnies) that may have built up inside, if your fan is gummed up it won't spin which then causes computer to overheat.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Dell latitude laptop-freezes after running for a few minutes/sometime on start-up/screen on but no response /fan stops running and nothing responds
Im assuming its a C64, these notebooks have overheating issues.
1. make sure the fan has room to breathe, and is clean of dust.
2 Dell Inspiron/Latitude/Precisiion fan control utility will help cool your processor ... http://www.diefer.de/i8kfan/index.html
Jun 04, 2009 | Dell Latitude C640 Notebook
Computer freezes constantly - has to be hard rebooted
HI it can be true if the fan stops processor overheat to prevent overheat. it should work all the time (when your pc is on ;))
Aug 15, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba Satellite 5005-S504 boots up sporadically
Hi, Sounds like the HDD is on its death march. I purchased the same Toshiha 507 from Ebay and after many Reloading attempts with Restoring to Factory System I deceived to purchase a NEW 80GB HDD from www.drivesolutions.com for 65.00usd. Now Laptop runs perfect.
God Luck on your Mission,
David Jensen
Jun 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Acer Aspire L100 PC Desktop Logo
170 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
