Question about HP iPAQ H2215 Pocket PC
Trackball connection I want to connect a serial trackball to the ipaq h2215. Is it possible? what kind of adapter do i need. the trackball is 'plug and play' and is microsoft mouse compatible, do i need drivers? i'm disabled and can't use a pda without a trackball. please help me out.
    Master:
  • 450 Answers
No, neither a trackball, nor a mouse can bne used with an iPAQ. The only mouse to be used with iPAQs is a bluetooth mouse.
Posted on Sep 12, 2005
SOURCE:
I want to connect my Pocket PC to my windows vista to transfer some pictures through bluetooth, how do i do it?
You should have a usb cable that either come with your Pocket Pc or you may have to buy one, so both machines can connect to eachother. Also if you have any software you will need to install this.
Hope this helps
Dec 10, 2008 | HP iPAQ H2215 Pocket PC
H2215 re-establish activesync
why not ask HP?>
not here,
this is not HP, its just a chat room
may take long time to get answers this THING is obsolete now
everyone uses smart phones now... so,,, help is lacking
as is connections.
hp activesync is not MS
https://support.hp.com/my-en/document/c00031253
its obsolete
but you can ask at HP>com not here, we are not HP
not in the least are we
here is the real HP form asking there is #1
get ready for laughs on dead products
https://h30434.www3.hp.com/
maybe you will luck out.
or learn to search the HP archives there
on IPAQ?
Jul 06, 2017 | HP iPAQ H2215 Pocket PC
Hi can I ask something?
u can download games from the website
http://www.ballshooter.com/ipaq_games/
Aug 16, 2008 | HP iPAQ H2215 Pocket PC
Startup shutdown
a new battery tried yet, battery tests , with a volt meter
only show if cells are shorted, or low charge state (SOC)
only load tests on battery show weak cells.
the top failure on something like this is the battery.
unless dropped.(and any fail possible)
HP has a real forum. why not ask there.
but battery, is top suspect
Jul 14, 2017 | HP iPAQ H2215 Pocket PC
Kensington 64215 PS2/ Serial Trackball on USB Mac?
Is the trackball supported by the MAC operating system? If available try the same setup, using the adapter, on a windows based computer to troubleshoot whether it is the trackball or the Mac.
Mar 24, 2008 | Kensington Expert Mouse Trackball
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Bluetooth problem
If I understand your setup, the computer's got the internet connection, and you want to bluetooth your wife's iPaq to the computer and through it out to the internet? And you've managed to pair the iPaq and the computer? Have you set up a pass-through relationship on the computer using ActiveSync? Good luck.
Sep 14, 2005 | HP iPAQ H2215 Pocket PC
Sync via bluetooth
Does your USB adapter provide serial port connections ? I had the same issue with an USB adapter with a dedicated-to-phone software. I changed to MSI bluetooth adapter and then made a serial port available to COM5, then connect activesync to COM5. (make sure on the ipaq you create a shortcut "activesync connection" and pair with the bluetooth adapter.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
HP iPAQ H2215 Pocket PC Logo
683 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
