Question about Sony Cyber-Shot DSC-F707 Digital Camera
F707 type of memory stick?
Hi, For a couple years I've been making do with the 128 meg memory stick I purchased when I bought the F707. The other day I decided to buy another or larger memory stick, however, the clerk did not know what type the F707 can use. Can it use both memory stick and memory stick pro, or only just the original memory stick? On both or either, what is the largest size now availalble? Brands? Is there any difference in quality/durability/longevity between brands? Thanks in advance. Andrew
    Master:
  • 551 Answers
I bought a Lexar 256MB, since the F707 can't use PRO or anything about 128mb, it has two 128mb on one stick. There's a switch on the stick to change it when the first 128mb is full.
Posted on Sep 12, 2005
Memory upgrade for Brother HL3040CN?
i had an old laptop laying around, pulled one of the mem chips out and stuck it in the printer. Works super great and no longer get an "out of memory" error. it was just a 128 meg stick of pc100 laptop ram
Jul 15, 2010 | Brother HL3040CN Laser Printer
I need to know more about a Gateway Performance 800 motherboard. I added a second 128 meg SDRAM 100 Mhz simm in bank 1 (the board came with a simm in bank 0). The BIOS recognizes the original simm as 128...
Check the specs for your new ram. It sounds like you have double density ram installed. If your motherboard only supports single density it will only see 1/2 of the modual hence 64meg showing for 128 stick.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 11, 2010 | Gateway Performance 800 PC Desktop
Can i use sony memory stick duo for sony cyber shoot DSC-F707
The answer is yes as long as they are the same type memorystick.
Feb 10, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Hi i have compaq presario 5000, detailed description would be P5700/P.4-1.6G/128M/40G/D16/M. i wanted to know which mother board is inside this PC and i wanted to upgrade my ram from 128 to 1 Gb. is it...
768 meg is the most you can put in the 5000 ..your system only has 128 meg so 768 would be a considerable improvment .... "crucial.com" is a great company to get reliable memory and information ... here is their page on your computer
http://www.crucial.com/store/listparts.aspx?model=Presario%205000%20Series%20Model%205000US
Oct 06, 2009 | Compaq Presario 5000 PC Desktop
I insert a memory stick and it says "No memory Stick" although it will take and record pictures . Does anyone know where i can purchase a 128 Memory stick for the DSC -F707?
You should purchase online from some secure seller.
Like here, its Sandisk Homepage.
search for the compatible Card from the bottom right tab.
Also Note that DSC -F707 doesn't support more than 128-Mb cards.
If helpful, Kindly DO RATE!
Best Regards.
Jul 17, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony digital dsc-f707 startup goes to "no memory stick"
Could be that the contacts on the camera are oxidised. Try cleaning the contacts with isopropyl alcohol and see if this helps. If not, it could indicate a circuitry problem. In this case, you'd probably be better off buying a new cam altogether!
Sep 28, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
DSC F707 Error C:13:01
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Aug 10, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory Stick Error
Have you tried re-formatting the cards? If you can't with the camera you should be able to with a card reader. It's probably the camera, unfortunately, but this is worth a shot...
Sep 13, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory stick problem
I had this same problem and the procedure it the following : IF YOU WANT TO SEE YOUR PICTURES, DOWNLOAD "PhotoRescue" INSERT YOUR MEMORY STICK CARD IN YOUR CAMERA, RUN THE SETUP1 AND FORMAT IT. Good luck
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony Cyber-Shot DSC-F707 Digital Camera Logo
109 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
