Question about Hotpoint Freezers
FZA 81 FREEZER-blocked drain
HOW TO UNBLOCK DRAIN.
my FZA81 freezer does not drain to the container but into the bottom of the freezer how do i unblock it
    President:
  • 1,462 Answers
Take back panel off inside freezer and you will probably find drain blocked by ice. melt off with a hairdryer and follow up with hot water till it flows freely away. takes a bit of patience
Posted on Aug 31, 2008
How do you unblock drain on fn360h freezer
What is blocked with ? if it is ice you need to melt the drain, if it is something inside the tube I would use a turkey baster with water in it and surge the water like a plunger .
Aug 31, 2014 | Freezers
Ice in the bottom of the freezer compartment
there should be a drain hole at the bottom of the freezer that goes to a evaporation pan underneath. check to see if the drain is clogged. in areas with high temps and or humidity there will be excessive moisture build up,the more the door is opened the more moisture (condensation). Clear the drain, it may just be blocked by ice, MAKE SURE THE UNIT IS LEVEL! This will let the moisture drain properly and prevent ice build up.
Apr 11, 2014 | Freezers
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Sep 16, 2009 | Woods Upright Freezer MU07W
I have a fridge freezer and found a small pool of water at back on floor
The drain hole at the inside bottom of your fridge freezer is blocked. locate and unblock
Jul 02, 2009 | Freezers
Suspect blocked frost free pipe
yep sounds like you have a bloked drain, u may have to pull the freezer apart inside to fix it
Apr 30, 2009 | Electrolux Freezer Kelvinator Single Door...
Drain iced up in freezer
the draining pipe is block with something, you can melt the ice with a hear drier or hot water, then put a wire true the pipe and after that, test the pipe again.
Jun 02, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Deep freezer drain
drain hole block-up. u need to defrost freezer
Apr 12, 2008 | Freezers
Freezers Logo
445 people viewed this question
Top Hotpoint Freezers Experts
Justin Duby
Justin Duby
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
