Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Pilot stays lit, but burners underneathe do not light up or burn.
Please advise us. heater laars lite 2 gas LG model for inground pool worked beginning of this summer. Now pilot stays lit, but no burners come on underneathe. thanks, kathy
  • kyamada2217 Aug 31, 2008
    Is this a Laars service technician? Where are their troubleshoot solutions? The manual doesn't have solutions.
  • dogsnuts Feb 28, 2009
    i have the same problem and have just ordered a new thermal generator which is being delivered mon so will let you know if it solves problem
  • 33 Answers
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Posted on Jan 17, 2010
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot stays lit, burner comes on but only a portion of the burner area has flames.
remove burn tray clean out all burners sounds like all sooted up then check gas pressure to see if adequate gas pressure
Sep 13, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
715 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
