Question about Car Audio & Video
Left Side of the car Speakers not working
2004 Nissan Sentra -My sepakers on the left side of the car (door and deck) stopped working (the little speaker on the windshield pillar slightly works) - the speakers on the right are working but it sounds staticy when adjusting the volume,
Could there be a short as both front door speakers (left and right) were recently replaced.
Look forward to hearing from you.
  • 1 more comment
  • Anonymous Mar 29, 2014
    and installation tools and accesories needed
    missing connector just wires
    no plug in for speaker harness just wires
    Master:
  • 623 Answers
Yes there is a short for sure re install all wires
make sure all connection are properly attached...
Posted on Aug 31, 2008
    Master:
  • 848 Answers
Yes there is certain chance for short circuit so better check whether the connections are proper ............
Both speakers on the left side has quit working
Try adjusting the balance or fade, it will be balance for left to right speakers to be adjusted, it may be as simple as this.
Apr 17, 2011 | 2004 Nissan Sentra
I just bought a 2004 Nissan sentra 1.8 S...I have two issues 1) my service engine light came on one day after I drove it off the lot. 2) there is no sound in left side speakers and both the right side...
the slimeball, um, person that sold you the car knew about the ck eng light. He cleared the codes, and after clearing the codes the ecm has to run tests, if a component fails the test 2 times, it turns the light on. You will need the trouble code to see what has failed. As for the speakers, did you find the balance knob on the radio?
Jun 11, 2010 | 2004 Nissan Sentra
2004 nissan sentra the driver side door lock
most likly need a door lock actuator for drivers door
Mar 20, 2010 | 2004 Nissan Sentra
How to....remove radio sepakers (rear) from a toyota echo??
It's really easy to remove the rear speakers. First, get in the trunk and find the 3 white anchors for the rear deck-they're near the rods for the trunk mechanism. Push them through the metal frame to free the deck. Next, you have to get in the back seat and remove the stop light from the deck. To do this, push in the pins on the locking mechanisms on either side of the light to free the back casing. Pull the pins out and the casing off. Next, undo the two bolts holding the stop light in place and pull it off-don't forget to undo the wiring harness. Next, find the three anchoring points for the back seat. Gently lift the two side ones free of their anchors. This gives you access underneath the deck. Free the deck and gently lift it over the seat. You'll have to jimmy it a little to get the locking clamps free--they're all along the back of the deck. Pull it free and you have access to the speakers. I believe the factory speakers are 5 1/4 inches
Try to use Toyota speaker adapter plugs so you don't need to cut wires and mess the electric system up. You can get them from Ebay or Amazon.
cheers
Oct 14, 2009 | 2000 Toyota ECHO
Problem with left side of all audio
Have you checked the balance foe left to right if it's full right no music will play through the speekers but you will still get the beep and other sounds like that that should be where you chand bass and treble settings along with fade center it and you should be good
Oct 04, 2009 | 2004 Nissan Sentra
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
I need a wiring color code for 2004 nissan sentra factory stereo.
I have the same car...04 nissan sentra....with the exact same problem....left side speakers just quit working. I still do not know what caused the problem, or how to fix it. I know it not the wiring, it is a defect within the stereo.
Mar 26, 2009 | 2004 Nissan Sentra
2001 Nissan Sentra something smoking under hood
I have a 1999 Nissan Sentra that is smoking from the passanger side of the car's hood. It stops when I turn the air conditioner off
Jul 19, 2008 | 1991 Nissan Sentra 2 Door
Car Audio & Video Logo
1,128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
