Question about Refrigerators
Error code de (defrost) coming on
I have a GE side by side TFX28PB refrigerator and the code de (defrost) is on and will not reset. What can I do or should I call a tech or just by another frige?
  • 1,543 Answers
I don't have manual here for that exact model, but the DE error comes up when the refrigerator has not detected a defrost current within a certain amount of time. This is most often the result of a burnt out defrost heater. The refrig will likely keep working for a week or so until the frost builds up and blocks the air flow over the evaporator (the cooling coils behind the back wall of the freezer). The defrost heater is located at the bottom of said evaporator. Although new refrig's are more energy efficient now, this one should be able to live on. If you don't want to attempt repair yourself, call a local tech. (not the utility company or the national guys ie: A & E.... too many hororr stories about them) You can try your zip code in http://www.geappliances.com/buy/ and look for a servicing dealer. (NOT the big boxes. look for the smaller dealers, Thats were you'll get the best and fastest service.
Posted on Aug 31, 2008
I have a Kenmore Elite 795 bottom refrigerator. I keep getting an error code r dh. I cycle the power & it goes away for approx. three days. looking for a proper fix
Defrost problem when the defrost process fails to reach the required temperature to properly de-ice the cooling coils.
http://www.searspartsdirect.com/refrigerator-repair/error-codes/kenmore-refrigerator-error-codes-for-795-bottom-freezer-models.html
When you cycle the power you reset the code and it takes a day or so for the unit to cycle the defrost. Suggest that you ensure that the vents are not blocked.
Hope this helps?
Nov 11, 2016 | Kenmore Refrigerators
My ge tfx28pb has water frozen at the bottom of the freezer, what is wrong
the drain is pluged with ice and causing the water to run onto the floor of freezer .. defrost drain with hot water and a turkey baster . this shoould solve problem .. mm
Aug 10, 2010 | GE PFS22SISSS Stainless Steel French Door...
I have a GE TFX28PB with an FF error light.
FF probably stands for "Frost Free". Yes. Your defrost circuit must have a temp sensor to tell it when the defrost is working. And for your fridge...it isnt.
The warm fridge/barely cold freezer are both common symptoms of extreme frosting of the cooling coils.
You need to manually defrost this unit and replace the defrost element and/or the controller board/power supply. You can buy them pretty cheaply online. Replacement is a lot easier if you just shut off the fridge and let it come to room temp before removing the coil cover.
Go to the GE website and get an online diagram of your fridge so you can see where the parts all reside. If you timer is mechanical it should have a way to manually trigger it to confirm the heater element works. IC based boards need special commands to go manual.....but you should be able to get this info from GE.
Good luck and be careful.
Sep 09, 2009 | GE PFS22SISSS Stainless Steel French Door...
I have an older side by side ge fridge with the panel display that shows pf - power failure de - cc etc well the de light has come on and I don't know what it means - I do not have the manual and I'm not...
The DE error comes up when the refrigerator has not detected adefrostcurrent within a certain amount of time. This is most often theresultof a burnt out defrost heater. The refrigeratorwill likelykeep working for a week or so until the frost builds up andblocks theair flow over the evaporator (the cooling coils behind theback wall ofthe freezer). The defrost heater is located at the bottomof saidevaporator.
Good luck.Please rate my answer if accepted.Thank you.
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
"DE" system light flashing
The DE error comes up when the refrigerator has not detected a defrostcurrent within a certain amount of time. This is most often the resultof a burnt out defrost heater. The refrigerator will likelykeep working for a week or so until the frost builds up and blocks theair flow over the evaporator (the cooling coils behind the back wall ofthe freezer). The defrost heater is located at the bottom of saidevaporator.
GE TFX24FHB system check shows problem code "de" but its still cold for now..
It sounds as though you may have an issue with the defrost system. If the system check shows an open circuit on the frost heater or an open circuit for the defrost thermostat when the temp in the freezer is at zero then you will get this problem.
I would keep an eye on it for a couple days and see if frost starts to accumulate on the rear wall of the freezer. If so you will manually have to defrost the freezer so the machine can maintain temperature. When you have the rear wall removed from the freezer you will need to check the resistance of the defrost heater.
Let me know how you make out and if you have anymore questions. Thanks,
Bill
Dec 21, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Ge side by side refer, no model number available at this time
a flashing DE usually indicates a defrost problem on any unit, they don't flash indicating they are in defrost, soner or latter the problem will show. You could have an intermittant bi-metal or most likely it being a ge - a bad defrost heater. and there is always the possibility that it could be the board. It would have to be trouble shot properly
Aug 04, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE TPG24BF Not Defrosting
replace the white sensor located on the top of the evaperator coil
May 10, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Refrigerators Logo
613 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
