Question about Motorola Mobility RAZR V3
Touchpad doesns't respond
The phone turns on, but the touchpad does not respond when I try to enter the lock code. Similarly, it rings when a call is coming in, but I cannot answer it.
  • 1 more comment
  • piazzafr Aug 31, 2008
  • Anonymous Sep 01, 2008
    I'm having the same problem. I can turn it on and off but nothing else works.
  • Anonymous Sep 03, 2008
    same here can turn off and on but keys locked came unlocked one time but locked up nexxt day
Same here...just started today out of the blue. very frustrating...mine also just starts beeping and entering the number 7 over and over again all by itself :(
Posted on Sep 02, 2008
I have problems when entering code on touchpad i have to push several times on the digit to here the beep i think my touchpad has a problem
You need a new keypad i had the same problem and when you replace it dont push too hard next time it wears the button out
Mar 23, 2014 | Weiser Lock Powerbolt 1000 Lock
My touchpad doesn't work on my aspire one D255 netbook. The wireless mouse works but the touchpad doesn't respond to any touch. How can I make the touch pad work? Is there a function?
Hi!
If the touchpad worked well before and suddenly doesn't work any more, it is most likely it was stopped by pressing the key combination FN F7. To be sure please press the same combination again and check if it works.
If it still not work, please check if the touchpad drivers are installed on you netbook.
To do so, please open device manager. (opening the device manager could be done in more different ways, e.g. click START button and, depending on your operating system enter devmgmt.msc in the Run box for windows XP or in the Search programs and files box in windows 7).
Now, under mice and other pointing devices you should find your touchpad.
If the touchpad is not listed in device manager, drivers for it have to be installed.
Drivers for your netbook's hardware are on the acer support page.
Hope it helped,
Bogdan
Aug 28, 2011 | Computers & Internet
Touchpad stopped working cannot move pointer arrow around screen
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
Jun 26, 2011 | Computers & Internet
Touchpad not working acer aspire 5732Z
Hope this helps.
Jun 16, 2011 | Computers & Internet
My samsung n148 touchpad is not working, i updated the drivers, but still not working... pls help....
Check if you accidentally locked the touchpad through the keyboard. If it is not locked, try to boot to Safe Mode and check if it responds, if not, just try to reinstall the operating system. If it still doesn't work then it needs repair.
Hope this helps.
Jun 03, 2011 | Computers & Internet
On my acer 5742-7645 my touchpad has stoped working?
Just check for the key combination on your keyboard (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
Hope this helps.
May 27, 2011 | Acer Aspire 5742Z-4200 Notebook
Touch pad is not working?
Hope this helps.
May 25, 2011 | NEC Versa FX Notebook
Touchpad not responding
I think try to check if the Touchpad is enable. The Touchpad Switch is the Number 3. Try to turn on or off the Touchpad from there.
Apr 23, 2011 | Acer Aspire 5516-5063 Notebook
My HP Mini 110 touchpad mouse is frozen. Pls help
Hello
If the touchpad does not responds then make sure that the touchpad lock switch (just above the touchpad) is not turned off.
If this doesn't work,Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load) You should see a menu "Select Last Known Good Configuration" and press Enter.This should solve the problem if not,try to download the synaptics drivers for any of the Mini 1000 series laptop edition as you have a Mini 110. It does works.
Apr 12, 2011 | HP Computers & Internet
IPhone touchpad only partially responding
I followed the following fix and it works. all rows are working based on this recommendation. I can not go to apple as I have used ziphone to unlock the iphone.
http://limitededitioniphone.com/iphone-touchscreen-fix-increase-sensitivity/
Jan 06, 2008 | Apple iPhone Smartphone
Motorola Mobility RAZR V3 Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
