Question about Dryers
Fan Blade came off - Aloha Breeze Model 12001 20" floor fan
The blade of my daughter's fan came off while operating. I took the cover off to repair it but there does not seem to be anything that holds the blade in place to prevent it from coming off in the future. It appears to be designed to just be fitted and forced onto the post that rotates. The fan is just 3 months old.
Am I missing something?
If the fan has a metal blade set... to quote a previous post.. there should be a set screw that keeps the blade in place. it should be behind the hub, and is most likely a small allen (hex) screw that fits into a small threaded hole. If there's just a hole the screw is lost.. you could probably substitute it, by finding a short machine screw with a small head (so it doesn't mess up balance) and the same thread type and size at a hardware store. You might even be able to find an identical one at Ace hardware or the like, since they tend to stock odd little parts. Issue will be finding the right thread type (coarse, fine, etc).. if it has a plastic blade set.. it'll most likely have nothing by but a hole in the back of the hub where the motor's shaft fits into (or the blade hub is forced onto). some of them have a spring clamp around the plastic. many don't, and over time, they do fall off (even the ones with the spring clamps). just stick em back on. Usually if they're falling off regularly, the motor is running hot and either the fan is not in a good place (not enough open space around it, both the front and rear need to have some open space) or it needs oiling. Issue with the latter is, you'd have to disassemble the motor, oil it (with SAE-20, 10W30, or 3-in-One, most anything works well), reassemble it, and whack it back into alignment. though if you're willing to do this once every 2 or so years (depends on the oil you use, SAE-20 and 10W30 can last up to 5 years), or once every year for fans running 24/7 or 12/7... you can get way more life than the manufacturers expect you to get out of the things. it's messy, takes some practice, but it isn't very dangerous (long as you unplug the thing before opening it up) and it'll save you money in the long run (oil costs less than fans and motors). (and yes, I know all modern fans contain a "permanently lubricated" motor. and did you know that is bupkis? as in bovine pudding.. or horse ****.. the current generation of fan motors use the same "technologies" as the ones made over 30.. even 40 years ago. the only difference is the size per watt ratio. they required regular oiling then, and they do now. they {the manufacturers} don't want you to oil them {and manufacture the motors so it's difficult to do so} because they don't want the things lasting very long. it's one of those conspiracies that no one really cares about because 'eh, screw it, i'll buy a new fan.' meh. I just don't think like that.)
Posted on Oct 17, 2008
THERE SHOULD BE A SET SCREW THAT KEEPS THE BLADE IN PLACE
Posted on Sep 02, 2008
Where can i get motor for Aloha Breeze Floor Fan Model 12001
online search or hvac / parts stores like granger , etc ==take the nombers off motor the get a match
Jul 08, 2017 | Dryers
Aloha breeze ceilinf fan model number 970003 does anyone know to to call 800 295 4448 number does not work
Why don't you get a better fan. You need to look for blade pitch in the fan. The higher the blade pitch,the better the air flow. This fan is worthless if you're looking for airflow.
Aug 01, 2013 | Aloha Housewares (93645) Ceiling Fan
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
Looking for replacement fan blade
google tower Aloha breeze fan blade? It will give you a bunch of sites
Jul 09, 2009 | Tower Aloha Breeze Fan
Need new blade for aloha breeze model 12001
most of your big BOX stores have replacements. problem is most sell them in 4 or 5 blades.
Jun 04, 2009 | Aloha Housewares Breeze 29" Tower Fan
Broken threaded plastic part to hold blade tight.Aloha Breeze Vintage Stand Fan Model 46051
Have you tried using the Evostik Superglue for Hard Plastics
It is brilliant for putting broken palstics back together again
May 25, 2009 | Tower Aloha Breeze Fan
The fan will not make a breeze at any speed
There is a switch to make it turn the opposite direction. you will need to flip the switch. Otherwise the fan blades are on upside down.
May 04, 2009 | Aloha Housewares (93645) Ceiling Fan
Dryers Logo
1,249 people viewed this question
Top Dryers Experts
