Question about Sony KV-36FS12 36" TV
SONY FD TRINITRON WEGA WITH HORIZONTAL LINES
I HAVE SONY FD TRINITRON WEGA KV-36FS12. ITS ABOUT 8 YEARS OLD. I NOTICED THAT NOW IT HAS FAINT HORIZONTAL LINES GOING THREW IT. I THOUGHT IT MIGHT BE A RECEPTION PROBLEM SO I DISCONNECTED ALL COMPONENTS. WITH NOTHING HOOKED UP TO THE TV I CAN STILL SEE THE LINES IN IT. THE COLOR IS VERY NICE AND EVERYTHIG ELSE SEEMS TO BE FINE. WHATS THE PROBLEM?
  • blacksheep71 Dec 03, 2008
    Yes, the lines are not actually horizontal. They are slightly slanted and get closer together when the resolution is increased.
  • 116 Answers
SOURCE: Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Posted on Mar 01, 2008
  • 4234 Answers
SOURCE: Sony FD Trinitron Wega KV-34HS430 TV
Since this seems to recover for a while, I'd first look for poor solder connections on the board. If you can solder, resolder any connection that appears grainy or has rings. Let me know if that resolves the problem. If not, the likely part is a bad capacitor in the kine bias circuit. I'll look up your specific model in that case and get you specifics.
Dan
Posted on Aug 26, 2008
Shuttle83
  • 1139 Answers
SOURCE: KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 23, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 115 Answers
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Posted on Oct 01, 2009
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Problem
The horizontal or vertical output transistors could be suspect in this case.
Oct 17, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv shows a white horizontal line and then shuts off
for sure the tube is bad be better off buying a new tv or find someone that has a tv repair shop
Oct 07, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony trinitron
the problem is that the horizontal blanking pulse wont tun off during horizontal retrace period. the problem is in the IC. that process the TV signal.
Apr 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Double images on my Sony FD Trinitron WEGA KV-27FS100
You may want to try disconnecting the power for about 30 seconds and rechecking the TV. Otherwise, it may not be worthwhile repairing.
May 29, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-36FS12 36" TV Logo
165 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
