Question about Espressione Caf? Dolce Aroma
Espressione Mirage The cleaning system cycle does not stop, it just keeps on going so we can no longer use the machine, checked the manual but have not found a solution, any advice?
  • 37 Answers
Please contact service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Nov 20, 2008
Semi automatic espresso machine shot won't stop pouring
Continuous water flow indicates a stuck valve. These suggestions may help depending on type of machine:
Full Automatic (Super Automatic); Valve needs back flushing, cleaning, or replacement. There is an off chance the dose needs re-programing.
Semi-Automatic; Valve needs back flushing, cleaning, or replacement. Check programing for dose.
Manual; Most manual espresso machines require operator to stop dose. (By releasing dose button or lever)
Arm style Manual "Jaw Breaker"; These are physically chambered dose which are unable to constant dose. Bad seals needs replacement (if you can still find them)
final comment to this 'open' question; All coffee machines needs periodic cleaning. Most espresso machines needs back flushing (not to be confused with de-scaling.) Usually a cleaning tablet or powder is poured into dose chamber (or back flush portafilter) and cleaning cycle or long dose is performed. This cleaner will loosen baked in coffee and push it out the pressure relief pipe. The machine will need to go into a normal dose cycle without coffee to flush the cleaner out of the valve and dosing system. Do this several times. Good daily cleaning habits will keep your machine in top condition.
Sep 30, 2017 | Coffee Makers & Espresso Machines
Espressione CA4865 Supremma Super Automatic machine will not transfer water into the system, but rather leaks out the bottom! What can be done to fix this?
I have same unit. Produced by Solac in Spain. No longer sold in U.S. Solac won't help.
I had leak out bottom of machine. Removed brew group and tightened phillips head towards front which was loose. This stopped the leak on mine. Hope it works for you.
Mar 27, 2011 | Espressione CA4865 Supremma Super...
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
Need owners manual
If you email this email they will send you whatever info you may need on the machine. e-mail: info@espressione.co.uk Hope this helps.
www.midstatebeverage.com
Nov 29, 2010 | Espressione Cafe Roma Deluxe 1329
I need a manual on the Espressione Luna Espresso Machine where can I find this
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000050587.pdf
Feb 05, 2010 | Espressione Luna Espresso Machine
Espresso is coming out like light brown foam
2 things:
1) yes, you can get a new plastic ring and any other part or service at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
2) or you can try taking off the brew head screen and removing the coffee oils.
instructions:
http://www.urnex.com/davidschomer.htm
Apr 11, 2008 | Espressione Cafe Roma Deluxe 1329
Espressione Dolce Aroma Deluxe and Espressione Mirage delluxe
I had the same spout malfunction proiblem. I never give up and I always manage to fix these kinds of things. I read this board called the company, they are clueless. Here is your answer: Remove the brewing unit and get a pair of pliers. With the pliers, gently jolt the the circular gearbox that rotates the brewing unit at the bottowm of the machine. It is the left hole of the 2 holes inside the unit on the bottom Gently move it clockwise. You will hear the gears make a faint noise like the machine does when it is on and spinning the brewing unit.
Now replace the unit and turn on the machine. Magic, the spout malfunction issue is gone and the machine works again. I had to do this several times before it worked. Apparently the spuse malfunction has something to do with aligning the dear box in the unit with the removable brew unit., Of course make sure the brew unit is aligned with the yellow marks before you replace it into the unit.
Jan 24, 2008 | Espressione Caf? Dolce Aroma
Espressione Retro Clogged?
I had the same problem with mine. unfortunatly you will need a special tool to remove the diffuser head. It' a very small spanner wrench that turns the special screw. I was able to make a spanner out of a screwdriver, but I'm a toolmaker by trade. Your best bet is to have it done by a qualified repair service. Also, if you damage the screw, it's imposible to get parts from them.
Nov 22, 2007 | Espressione Retro 1385 Espresso Machine
Espressione Caf? Dolce Aroma Logo
131 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Douglas Dinnebeil
Douglas Dinnebeil
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
