HI! can somebody help me? I have an old dos data-processing
program.After reinstalling windows it doesnt want to work.It is
opening, but just after opening an other window in it, it writes error,
I have to close it.
What I already did:
Copied config.nt and autoexec.nt in the folder where tde program is.I changed FILES=85. The autoexecnt now looks like:
@echo off
lh %SYSTEMROOT%\system32\mscdexnt.exe
lh %SYSTEMROOT%\system32\redir
lh %SYSTEMROOT%\system32\dosx
SET BLASTER=A220 I5 D1 P330 T3
In Properties-Program-Advanced I rewrote the path.
The compatibility is on windows95.
All of the memory is on auto./????/
I dont know what else i have to change, this program worked me beforeI didnt reinstall win.
Thanks for your help.
Well that information has told me that you should not install it on your computer, the reason being that it may effect windows and can case unreverseable damage. Sorry.
RCF
I found some more information and I have found that ADAM will NOT dangerously affect your system. I will send you a link. If you read that. That may help with your problem. If it dosen't tell me again exactly, with as much detail as you can, what your problem is. Okay?
RCF
Here it is
http://www.warp2search.net/contentteller...
Well that means that your system is on the verge of a major crash, which may damage many components of the system, s I trecomen you uninstall it now, I am sorry, but I am unfarminiar with this progfram and I don't want to risk the crashing of your system.
RCF
Hello sir
i have f500 compaq laptop i have no winxp driver in sound driver plz help me
thanks
Hi
Ryan5443!I dont know will it help you, but my program is called ADAM Plus /w_adam/ for data processing and has about thousand years.. Irs written here in the instructions that it was made in FoxPro 2.6. It needs: PC386 or more, 4MB op.memory,MS DOS 5.0 or more, cca 15MB empty space on disk.Thats all what I found.
oparatomas!
I canĀ“t find anything about my problem on thelink you gave me. Im sorry.
Can anybody help me, please?
HI Ryan5443,Ok, thanks,just send me that link, I will read it!
Im afraid,I dont have that kind of "ADAM".
It seems that mine adam is the name of the program, so dont bother with it.
Shortly:
I have an old, very simple DOS program/fox pro/.
Lat time, when I reinstalled windows, it was enough to rewrite FILES=85 in config NT and it worked normally.
Now I can open it,write my password, but then In a big red screen it writes: serious error, the system has to close - and it closes.
So thats it.
I think it has to be in connection with memory, but I already dont have idea where what to rewrite. It would be good if you could send a copy how exactly the config and autoxec has to look like.
Please help if you can.Thanks.
Although you want to have this program I am going to warn you that if you put any DOS program on the computer you can potentially completely damage the OS. So it is not recommended. But I need to know the exact name of the program m in order to help you.
RCF
