Question about Dell E172FP 17" LCD Flat Panel Monitor
Intermittent Power When I plug in my monitor (without having touched the power button) I get 2 seconds on, then off, then 2 seconds on, then off. The fuse is good and there is a clicking on the power board inside the monitor itself. Anyone have a schematic for this one? It's made by Benq. E172FPb,When I plug in my monitor (without having touched the power button) I get 2 seconds on, then off, then 2 seconds on, then off. The fuse is good and there is a clicking on the power board inside the monitor itself. Anyone have a schematic for this one? It's made by Benq.
    Sergeant:
    Champion:
  • 275 Answers
That means the power button is bad or some wire on the button is loose
Posted on Nov 20, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
I have AOC e943Fwsk monitor. I can't turn it off with power button. what should I do now?
Unplug it and hold the off -on button in for about 30 seconds then plug it in and see if it works.
Sep 20, 2014 | AOC E943fwsk 18.5" Led Lcd Monitor - 5 Ms
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computers & Internet
What is combination for entering service menu on LG M1962D?
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Jan 18, 2011 | LG M1962D Monitor
HP L2208W monitor. Unplugged it, working perfectly, moved it (carefully) to another desk, now it only says "no input signal", but stranger is the fact that it comes on as soon as it is plugged...
nosignal means the PC its plugged into , is not sending
the 2 sync, signals, horiz./vertical.
so make sure the PC works,first, then the cable them the monitor.
this monitor is old as 2007. 1 decade old.
is the cable plugged in to the same jacks as it was.
the PC caN in fact have many jacks, DVI or VGA. even 3:
the monitor can have 2 jacks use the primary. yours has 2.
one DVI and 1 VGA.
self power on feature...hummm, the opposite of any energy saver scheme...
is the bottom right monitor button power damaged? look carefully.
to reset the monitor, unplug monitor from wall power AC
then hold the power button for 10 seconds.
release.
does it work now?
the odd self power on the power lamp shows? page23 your manual.
Green = Fully powered.
Amber = Sleep mode.
Flashing Amber = Sleep Timer mode.
ok page 26 in your manual shows there is an auto power on feature, I just read it for you. in your OSD menu.
"Power On Recall
Restores power to the monitor following an
unexpected removal of power. Select:
On
Off <**************************
The factory default is On."
NOT FRIED, at all I bet.
1: wrong cables used or plugged in wrong
2: PC died. in the move, sure can, test PC with another monitor
if fails PC is failed, if not , not.
3: wrong jacks used.
4: cable died.
Oct 26, 2017 | HP L2208W Monitor
OSD locked how do I unlock
OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Sep 11, 2009 | AOC 917Sw 19" LCD Monitor
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
Dell E172FP 17" LCD Flat Panel Monitor Logo
190 people viewed this question
Alun Cox
