Question about Dell 942 All-In-One InkJet Printer
Dell Printer carrierjam
I changed the ink cartridges and now it will not let me print. I have taken them out 3 times and it still tells me its jam.
  • tjcpcc Nov 28, 2008
    i have a carrier jam and nothing seems to work
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
The printer is telling me that the ink cartridge is jammed. How do I fix this?
Turn the printer on.
Lift the lid that covers the print-head mechanism.
It should slide across; if it does not, it is "jammed".
Remove any object that is physically blocking the path of the print-head.
May 11, 2011 | Dell V313w AllInOne InkJet Printer
Says there is a jam with the ink carriage. I just put new ones in and its telling me there is a jam
If the number 10 cartridges are not properly fitted in the print head then this might give you a "jam" signal. My ink cartridges snap easily into position... if out of position an ink cartridge can block carriage movement...it happened to me.
Jul 01, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Ink cartrige dell 1110
Maryfrancesh
Exerpt taken from Dell Laser 1100 User Manual (p30)
1 Open the front cover.
2 Pull the used toner cartridge out and lift it up and away from the printer.
3 Unpack a new toner cartridge. Hold the cartridge carefully and gently shake it from sideto-
side 5 or 6 times to distribute the toner.
4 Pull the tape to remove the protective paper.
5 Locate the cartridge slot inside the printer, one on each side.
6 Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until
it snaps into place.
7 Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed,
printing errors may occur.
PDF Manual can be found here -->
http://support.euro.dell.com/support/edocs/systems/1100/en/OM/OM_1100_en.pdf
The guide also contains pictures of what to do.
Andy
Jan 29, 2009 | Dell 1110 Laser Printer
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 964
i suggest yo contact dell, they may be able to send you some ink cartridges for testing or you could purchase some new ink (if the new inks doesnt work then its a hardware issue)
Feb 22, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell A940 Color Ink Problem
Do check the option and make sure that you have not inadvertently set it to black only- This could be computer wise or on the A940 panel. If you are sure all is well here Remove the scanner software and reinstall. Email Dell to See what they have to say
May 08, 2007 | Dell A940 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
143 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
