Question about Campbell Hausfeld 26 - Gallon Air Compressor
Adjust PSI How can adjust the psi on this compressor? I am using this with a angled nail for 3/8inch hoardwood and it is damaging the wood. Thanks
  • 39 Answers
There should be a regulator on the output line, looks like this, http://www.aircompressors.us.com/store/i/is.aspx?path=/Shared/images/Powermate/019-0188CT.jpg&lr=t&bw=300&bh=300
by turning the top portion of the regulator you adjust the pressure
Posted on Oct 11, 2008
The compressor does not get over 40 psi. It simply does not pump over that.
Posted on Sep 12, 2008
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
How do I stop my compressor from prematurly turning on ?
you can adjust the "cut in" set point to a lower pressure. your pressure switch has a screw that you can turn out to lower the set point.
Dec 09, 2014 | Dewalt D55140 1 Gallon 135 PSI Max, Trim...
Nailer firing weak
Usually this is an air pressure problem. You can safely set your compressor anywhere between 90 -110 psi for nail guns.
Also check the adjuster near the nose of the gun. It's usually a little wheel that you turn to adjust nail firing depth.
Jan 24, 2014 | Cars & Trucks
Nail gun 58-8434-4 will not drive 3" nails all the
Hi foxden503,
Welcome to fixya!
As a general rule, framing nailers use anywhere from 45 to 120 psi to drive nails. But this also depends on the hardness of the wood.
The nail head should be flush with the surface. If it sticks above the wood, increase the pressure a little bit at a time until you achieve this goal.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 20, 2011 | Tools & Hardware - Others
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
I have a RN45B roof nail gun that wont sink the nails all the way. How do I adjust depth of nails?
The adjustment is inside the magazine there are 3 setting depending on the length of nail. Here is a PDF of the owners manual for that tool, the procedure to set the depth is on page 6. http://www.bostitch.com/catalog_images/web_pdf/103280.pdf
If after setting the depth you are still having issues you can adjust the pressure on your compressor. The operating pressure for that unit is 70 - 100 psi. Do not exceed 100 psi and remember to disconnect your hose before loading/unloading or making adjustments to your nailer.
Oct 10, 2010 | Garden
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
GUN NOT SETTING NAILS
Hello jsc.... the depth that the nailer drives the nail is dependent upon two factors, the hardness of the material you are driving the nail into and the air pressure. Generally when you want the nail to go in more you adjust the air pressure to a higher setting, going 5 psi at a time until you are close to perfect and then fine tuning the air pressure.
Sometimes people find that the air compressor itself is inadequate for the job. in that case, the only choice is to move up to a higher psi compressor. Joe
Thanks for choosing Fixya!
Jul 04, 2010 | Hitachi 3 - 1/2" Full Roundhead Framing...
Will a 1/3 hp compressor fire an 18 guage 5/8'-2" Finish nailer?
You compessor is ideal for a small spray gun however a pin nailer requires 80 to 100 psi and a small air storage thank to operate properly. The nailer may very well shoot a short nail into very soft wood at 30 psi, however there may not be enough pressure to push the piston back to top positon to load another nail and fire again. Good Luck
Jan 31, 2009 | Air Tools & Compressors
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
164 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
