Question about HP LaserJet 2100 Printer
Extra printed page on HP LJ 2100
Whenever i print a document on my laser, it prints an extra page of paper which has *slM in the upper left corner. Other than that it works fine.
  • 18 Answers
I would first suggest making sure you have the latest drivers for your laser. Even if you do confirm this I would then reinstall them. If that is no help, it may be a connection issue (bad cable or port causing noise when you print).
Posted on Oct 14, 2008
Canon mg2520
This is usually a Word option.
In Word versions prior to Word 2007:
1.Click the Tools->Options menu item.
2.Select the Print tab.
3.Make sure Include with document/Document Properties is DEselected.
4.Click OK.
In Word 2007:
1.Click the round Office button in the upper-left corner of the window.
2.Click the Word Options button.
3.Click Display.
4.Under Printing Options, uncheck Print Document Properties.
5.Click OK.
Jul 22, 2014 | Canon PIXMA MG2520 Inkjet All-in-One...
After turning on printer, prints initial "blank" sheet
You can fix this by turning off bidirectional support:
- Right click your printer, select properties
- go to the ports tab, uncheck Enable bidirectional support.
Your printer has to be turned on before printing.
That fixed the extra page printing S1M problem for me.
Oct 11, 2009 | HP LaserJet 4 plus Printer
Laserjet 2100 prints code
Install the HP LJ III driver and this should work as advertised.
May 22, 2009 | HP LaserJet 2100 Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Canon MP600 not printing on full page - in upper left corner
I went to the Canon website and downloaded the drivers for the printer and it printed out right--on a full page.
Feb 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Printing Problem
Check your printer driver for the paper setting, under properties. Make sure it is set to letter. Otherwise reset the power of the unit and/or reinstall the driver.
Jun 30, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Feb 29, 2008 | HP LaserJet 5550dtn Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
HP LaserJet 2100 Printer Logo
112 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
