Question about Asko Washing Machines
Drum won't rotate to wash or spin. - Asko Washing Machines
    President:
  • 1,462 Answers
For a start, check the motor brushes
Posted on Aug 31, 2008
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
The drum in my washer will not rotate. Are they belt or direct drive?
Every washer I have dealt with have all been direct driven through a transmission. There are several reasons that a washer drum will not rotate. The simplest reason is that the door interlock is not functioning properly.
Aug 05, 2016 | Washing Machines
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
