Installed a new cartridge, got a "left cartridge error" message. Fiddled with it for a while, ended up getting an "error 1203" message. Unplugged and replugged the machine from the power outlet, am now getting "left cartridge error" message again. I have removed and replaced the cartridge about three times, no help at all.
I had the same prob..... I fixed it I took a clean soft rag sprayed Windex on it wiped off the ic type board on the front of the cartridge and also the board on the inside that the cartridge rest up against,,, turned it off and on put a copy under the scanner and kaabam it printed a month of pulling my hair out it works
If the old cartridge can be detected and the new ones are not
Try rubbing the metal contact on the ink cartridge with cotton or clean clothes there is a very thin film covering the contact that sometimes prevented the Printer from recognizing the Cartridge
At whatever point you get into any glitches identified with Dell printers, the help bundle with willing dependably be accessible to help you in the best way and with handy goals. Guaranteed and gifted experts can inquire about your issues on the arrangement. The help specialists with working for the duration of the day, reliably with stunning imperativeness to pass on an association when you need it most. In spite of whether you are facing printer bugs, paper staying issues, low-quality prints, establishment disappointment, driver or programming establishment issues or some various issues, the Dell Printer customer administration will dependably bolster you by endeavoring their earnest undertakings. Get minute targets by basically pushing toward sans toll number. Dell Printer Tech Support Phone Number +1-833-260-7367
https://www.onesearchpoint.com/dell-printer-support-phone-number/
Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
If your Dell 926 fails to recognize the print cartridges after following the above instructions,
take it to a repair shop for servicing.
Good Luck and Happy Printing
Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
Push the scanner support bar back to release it. Lower the printer unit until it is closed.
Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
I hope this clears up your problem.
Good Luck and Have a Nice Day!!
After replacing the ink in my cartridge, I've had an error message: 1203. I've repeatedly taken out the cartridge & placed it back in, but still my printer fails to work properly & remove the error msg. How can I fix this problem?
replaced the cartridge and keep getting erroe 1203??!!! I dont know what to do I have unistalled it and reinstalled it, taking the cartridges out again and again. HELP!!!!
any help?
same problem... my guess is this printer sucks!
having same problem nothing is working i dont know what else to do. i need to use the printer now. help
I installed a new cartridge and now I'm getting left cartridge missing message on my printer.
im running windows 7... just installed new ink cartriges that i ordered from swiftink.com and I am getting the same problem. I tried poohkies solution and this still didnt solve my problem.
any help?
David
Posted by Guest on Feb 01, 2009I installed a new cartridge and now I'm getting left cartridge missing message on my printer.
Same damn problem everyone else is having, error 1203 on a dell 926 series 9 printer, i un and re plug it in, take out and put cartridges back in, and restart it and re install it and still NOTHING works. I hate this stupid thing. I need a report printed out NOW and NO way of fixing it.
replaced cartridge in 926 with new series 9 cartridge from Dell. Left print cartridge error (says wrong cartridge). Did not work with 2nd new. Anyone find cure?
keep getting a "left cartridge incorrect" error. printed fine yesterday. taking cartridge out and putting back in doesn't correct problem
Same problems that are described with Del 962 printer. Left cartridge incorrect. Is it an ink cartridge made in the Pillippines problem, or a real one?
