Question about Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W won't spin
Hi
Please someone help. Our Zanussi FJS1225W is about 5 yrs old and has been working well, it will drain and programme, but won't spin. Someone said to change the motor brushes but I don't know where they are located?
Thanks
Andy
    President:
  • 1,462 Answers
Motor brushes can be replaced in situ but you will find it easier to remove the motor.
take the rear cabinet half off and undo electrical connections to motor. motor is held in by 4 bolts. undo and motor will slip out.
brushes are located towards the end away from the pulley and held in by 2 small bolts. undo, withdraw brushes and see if badly worn
easier way is to check continuity across the brushes with the motor in situ using a multimeter
Posted on Aug 31, 2008
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
Start light flicking on and off
Hi - I have had the same problem. My husband just fixed the pump as the water was not draining out. When we turned the machine on again the door light was flashing and no water was going into the machine. I just tried a solution posted from here by someone else which was to turn the machine on and then hold down the start and the reset buttons simultaneously for 5 seconds. Hey presto, machine now working!
Sep 03, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
Zanussi zwf1929w front loader
it could be either the heating element the machine is waiting to heat up before moving on or the brushes on the motor. somtimes the motor is able to spin without a load but struggles full up programmer faulty is a rare fault
Oct 30, 2008 | Zanussi FJS1225W Front Load Washer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Long time to dry
Check drain filter on front of machine and check machine is doing full spin. Regards Advisor
Aug 20, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
371 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
