Acoustic solutions mp3 player
This mp3 only turns on with logo and blue light, does not turn off and once plugged into the pc says ready with blue light, but nothing else, i cannot creat a folder for it, as the file f which comes up, states it is corrupt, please help.
  • 3 more comments
  • hizafar1978 Sep 20, 2008
    My FM- 6611device is not working. When i switch My acoustic solutions mp3 player to a computer the ready mode with blue light appears on the device but when i double click the device tab a massage appears that (the disk in the drive I is not formatted Do you want to format it now) as i click the yes tab no function takes place.
  • Anonymous Oct 12, 2008
    when i try and play my mp3 i click the on button and a blue light comes on with the acoustic solutions logo but nothing else happens
  • Anonymous Mar 05, 2009
    Im also stuck cannot get cannot access to format or nothing and cannot get into mp3 player menu
  • Anonymous Apr 02, 2009
    maannnnnnnnnn i am dying i wantit working come on peeple heeeeeelppppppp
  • Anonymous Apr 27, 2009
    its not downloading niether is it formatting.
When i try and play my mp3 i click the on button and a blue light comes on with the acoustic solutions logo but nothing else happens
Posted on Aug 28, 2010
Eclipse mp3 player 4g wont charge
Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
May 04, 2012 | Mach Speed Eclipse 180 MP3 Player
Won't turn on past logo
well, when my phillips will not go past the go gear screen its got a little lock symbol, which means its locked which means you cant turn it on or plug it into a pc/laptop and if u do it wont do anything that could be your problem.
Feb 28, 2010 | Philips GOGEAR SA6045 MP3 Player
Lost disk to install my acoustic solution mp3
Try this,put it in MSC mode,Plug into your computer,open My Computer,(The player will show as a drive)Open up the player,open the folders and delete what you want deleted.Then when you want to add more songs,Open it the same way as above and drag and drop them.You do NOT need to use a media player to load or remove items.And Please rate this solution.
Jan 11, 2009 | SanDisk Sansa m240 MP3 Player
Help my creative zen v plus freezes and wouldnt start up.
**** YOURSELF AND THEN TRY TO TURN IT ON IT ACTUALLY WORKS ... DON'T BELIEVE ME GO DO IT
Nov 08, 2008 | Creative Labs Zen V MP3 Player
Hi
If it's an IPOD I found this solution http://www.apple.com/support/ipod/five_rs/nano3gen/#
This was the procedure for my 3rd generation NANO.
Step 1 has never worked for me but the reset has worked so far.
Hope this helps
Ann Mckay
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Sep 02, 2008 | Audio Players & Recorders
Disk doesn't work
"Hard-disk Problem"... I'd just like to confirm once more that smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I didn't try smacking it till I checked out the threads above so thanks everyone I'm a happy man again!! :)
you can replace the hard drive with a flash drive to fix this.
Feb 18, 2008 | Creative Labs Zen Micro MP3 Player
Won't Turn on
It seems to me like your mp3 player booting software has corrupt, keep trying it it doesn't work after so long you may need to format your mp3 player.
To format you can use the software provided (if there was any.) If there wasn't any software provided follow these steps below:
First connect your mp3 player to the computer, once you've done that go to "Start" - "My Computer" - now look for something called "Removable Disk" which is your mp3 player, once you've found it "Right-click" on it then click "Format", once format as complete put music back on your mp3 player then, unplug it from your PC/Laptop which ever you have, then try switching it on & the problem should have been fixed.
Good luck. Hope my solution was helpful in some way. Further problems, leave a comment on here and i will get back to you a.s.a.p.
Nov 25, 2007 | iLO (2 GB) MP3 Player
MP3 player something wrong
Hi Samusv2,
Try removing the battery completely for about 1 minute, then put it back in then try to see if doe shte same thing. Insert another comment on this post and I will respond.  Cross your fingers.
Oct 13, 2007 | GoVideo Rave-MP ARC5.0 MP3 Player
My Thingy Won't Work.
i have this same problem, but i don't know how to sort it other than taking the battery out, plugging it into the computer or plugging it into a battery pack if you have one. sorry!
May 31, 2007 | Creative Labs Zen Micro MP3 Player
Ive tried the solutions posted here all ready
This is not much of a solution but I pulled my battery out then put in back in. Once I powered on the unit, I get the Creative logo, it updates the library and I'm back up. BUT, then I tried to sync again, and again, and again. Same result each time. I also found that it will not sync past 50% of anything I try, 1 song, 1 album, 100 songs or 100 albums. It always freezes and I can't power off.
Dec 17, 2006 | Creative Labs Zen MicroPhoto MP3 Player
907 people viewed this question
 Grubhead
Grubhead
