Question about Maytag MSD2656G Side by Side Refrigerator
Ice build up on bottom of freezer
Ice builds up on the bottom of the freezer. i scraped it all out but it formed again in a few days. finally i was greeted by a nice size puddle in front of the freezer door.
  • Maytag Master
  • 5,568 Answers
For units with automatic defrosting, there is a drain, sometimes concealed, for the defrosted ice (water) to drain into a removable pan under the coils below the two compartments.
I suspect this is clogged with bits of debris and preventing the melt-water from dripping into the pan.
Check under your ref./freezer behind a trim grill for this pan and check the condition of it; overflowing or empty.
Normally, the fan that blows ambient air through the coils keeps this pan dry-to-moist.
It's fairly shallow so if your ice maker is leaking it will overflow but it should normally only be wet for a short time after the defrost cycle.
If it is pretty dry, note which side is wet. If it is wet under the freezer section, the clog might be loacted there.
If you do not see any holes that could be a drain in either side of the fridge, you could have a more serious problem trying to free it.
Each liner is made as one piece to help keep the inside free of dirt traps but there may be access panels and if they are found low and in the back, they may be intended to access a drain.
If you are lucky enough to find a hole toward the bottom, you should be able to free the drain.
Depending on the location for access, you should be careful poking anything too stiff (like a screwdriver) into it as the coils could be damaged.
Something like a piece of 18 gauge copper wire would be better.
Posted on Aug 31, 2008
Ice in the bottom of the freezer
Check the door gasket for a leak. Air entering past the gasket will form ice.
Sep 23, 2014 | LG LRBN22514ST Bottom Freezer Refrigerator
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer keeps building up ice on the condenser i think, and after a few day sitting the bottom part of the freezer freezes and the rest dont
I'm not sure what system you have but typically there is a defrost timer on the back of the fridge. Often you can barely detect where it is, as only the stem sticks out.
What worries me is the amount of moisture in your fridge. You did not indicate how long to make the build up, check your seals carefully with a dollar bill.
Sep 02, 2013 | Refrigerators
Discovered ice build up on bottom of freezer in side by side KitchenAid Superba. Figure it is a defrost drain clog.... How do clear the clog?
I have ice in the bottom of my freezer section also in an older one of these, but I have traced it down to some sort of leak in my ice maker line. It only occurs when the ice maker is making ice, and not when the ice tray is full. Mine also leaks through the front door seal and into the floor if I don't keep scraping out the ice from the bottom (to clear out the "reservoir" that holds the water till it turns to ice).
I came on this site looking for a way to locate the leak and get to it. You might try scraping out the ice and turning off the ice maker for a while and see if the ice no longer forms at the bottom. Then at least you have localized it a little!
Feb 09, 2011 | KitchenAid Superba KSRG25FK Side by Side...
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
May 07, 2009 | Refrigerators
Water builds up in the bottom of freezer
had this happen once and my drain was clogged. in the freezer section you have to remove the rear panel. 2 1/4 screw bolts. after exposing the coils the drain hole is in the middle. i clesred the hole with my wet/dry vacuum. first sucked then blew air through it. hasn't done it again and its been 1 year so far
Apr 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Mar 21, 2008 | Refrigerators
Maytag MSD2656G Side by Side Refrigerator Logo
209 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
