Question about RCA RT2300 System
Roars The base roars for about 20 seconds after turning it on. I have the surround sound which has a base to work from because I have a DVD player already in the tv. I bought it at Walmart and have no paperwork to try to return it, I think the speakers work fine, I just want to know if this roar means it is going bad??? Or is something I need to do??? It says it canbuzz if too close to the tv but that isn't the case.
  • cdog648 Sep 02, 2008
    I need to know what to do with this problem. The system is less than a month old.
  • RCA Master
  • 13,433 Answers
Your system is less than a month old? And for sure covered by warranty contact your dealer for those free warranty repairs.
Thanks,
Ekse
Posted on Sep 02, 2008
  • RCA Master
  • 19,396 Answers
This roar means one of the amp components has gone faulty, often it stays like that for ages and do not get worse.
Sonetimes one day amp final IC or transistor will fail completely and you get no sound.
  • Ginko
    Ginko Sep 02, 2008
    the buzz is different, it is a continuous humming nois from bad shieldingor interference.
    A growing in volume huuummmMMMMM (and sometimes bang) is a defective amp.
    Often it stays like that for a long time.
  • Ginko
    Ginko Sep 02, 2008
    First ensure it is not a disturbance from TV or any nearby device (eg. power adapters).
    Generally , if the noise raise up in volume anthen goes it is a faulty amp.
    If the problem goes as you whack (gently) or move the unit then it is a bad contact or connector inside.
    If you just bought the item I would replace it, even if problem
    disappears by moving the device or whacking it, it means the machine
    has a fault that can come back in time.
    If product is not brand new, but covered with guaranty take in for repairs. If it is less than one moth old warranty will cover the repair or replacement.
Chrysler town country noise
Your cars engine "roars" or the fan motor "roars"? If its the engine, does your car have tachometer and what are the rpms?
Oct 16, 2013 | Cars & Trucks
2008 Jeep Liberty Starter Issue
cant figure out your post at all !
"When my car will not start it only growls & never roars/never turns over."
it either cranks robustly nor not
then and only the can it start, run
cranks
starts
runs
or maybe stalls
the dealer can fix it , if you demo it and it works.
its not broken then.
if it cranks correctly every time ,say so
that is a failed engine start.
if engine stalls, say so.
if rpm on the engine is real low, too low, say so.
the word turns over means nothing, Im sorry
1/2 say, it means cranking
other 1/2 means its running,
the order is
cranks, starts, runs , and keeps running or stalls.
btw if it stalls, its needs a tuneup'
get one in last decade, (sparks filters)
my guess growls is starter sounds
so if it starter works try cranking with throttle wide open
this is super secret unflood mod. it cuts fuel and clears flooding.
Good engines that fail to start are
bad spark plugs
flooding
starving for fuel.
we discount them 1 by one until. bingo
Mar 08, 2017 | 2008 Jeep Liberty
Engine roars when I start it
Hi, when you describe roars, is the engine RPM going way up? Please clarify. How many miles are on the Jeep?
Oct 11, 2011 | 1999 Jeep Grand Cherokee
Singer 5525 model just roars
Unfortunately, you will have to call the shop and tell the them the problem is not fixed.
Ask if when you bring it in, can you do a show & tell with the tech and then give a demonstration.
Mar 31, 2010 | Singer 8280 Mechanical Sewing Machine
American standard kitchen faucet roars when hot water turned on
Not the aerator at all as this part would act the same if hot or cold.
Have you checked the shut-off valves under the sink? Sometimes just turning them a bit in either direction will solve that problem (will only be the case if it have been shut off at the valve recently).
Also, maybe the supply line on the hot side have been kinked?
Hope this helps
Apr 11, 2009 | American Standard Plumbing
Roars when spin cycle
You are right it is the bearing also called a tripple lip seal and there are special tool to do that job if it has a metal outer tub I would not repair it. If it has a plastic outer tub the repair will fix it
Mar 29, 2009 | Maytag HAV4657 Top Load Washer
Shift Automatic
Your secondary has went bad in your transmission, you need ot have it replaced.
Oct 26, 2008 | 1997 Ford Escort
RCA RT2300 System Logo
280 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
