Hello, Timcampbell82 -
I have tried to find a user's manual for a Rosieres F200T oven for you. I suspect the user's manual states what temperature each of the numbers for the degree knob represent.
So far, I have not found a manual online for you. I did find an online forum in French, with mention of a manual for the oven model, but the messages date from 2008:
https://www.meilleurduchef.com/fr/forum/notice_materiel/1225015073-14054-650
You may wish to locate a business in your area which performs repairs for Rosieres ovens and ask if they can find a manual you can purchase for your model oven. Or, perhaps one of the repair technicians can tell you what temperature each number represents.
Best wishes.
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
SOURCE: how to install oven igniters in Viking VGR48-6GD
Please click on the below link.You will get some ideas to replace it.Everything is explained with the pics.
http://www.explorerforum.com/forums/showthread.php?t=217691
SOURCE: translate temp gauge numbers to degrees
I recommend you buy a cheap oven thermometer and check the oven temperature yourself. As a gasfitter I know temperature conversions (numbers to degrees) are approximate and I think may be done on purpose so consumers won't complain if they put a thermometer int he oven and it differs from the thermostat. Check the temperature in the centre of the oven. do not use pans and trays that fill the sheld as gas ovens need room to circulate the hot air. Also do not place items in the oven so the top of it is near the top of the oven - otherwise it will burn. I have found when cooking a chicken it needs to be turned otherwist the bottom of it may not be cooked.
Cheers
John
Testimonial: "OK will do that next time I am in town. I know all ovens are different I just wanted a rough idea so I dont ruin too many meals!!"
SOURCE: My oven cooks too hot, about 75 degrees too
find an appliance parts outlet and give them the model number and tell them you need a new oven thermocouple,you maybe able to just replace the thermocouple,or you may need to replace both due to being connected together
SOURCE: hi there- the digital temp
Hi Ruby
The issue is with the oven temp. sensor going bad and should be replaced. Please check this to locate oven temp. sensor:
Hope this helps....please let me know if you need further assistance.
Daniel
