Sony DAV-BC150 System
Problem for Sony DAV-BC150 System
Hcd bc150 main power
By chirca on Aug 31, 2008
hi.my name is patrick im from Romania and i receve from a friend from USA a SONY sistem HCD BC150 and i want to know what is the range power.In Romania electricity is 220V in states is 110V.Inside of the sistem is writing something about 245V max voltage on the dash board can i put him on 220V ? Or i have to find somethig to reduce the power from 220V at 110V? Please help me.this is my maill adress chirca_petrica@yahoo.com Thank very much,and have a nice day
Comments:
Aug 31, 2008
- there is no swich on the rear :( so what can i do ?
Aug 31, 2008
- inside on the electrical board is writing something about 245V but it is a fuse now i see better what it is.At the end of power cord it's not an transformator the source is in comutation....
Aug 31, 2008
- on the label is : AC:110V 60Hz 100W nothing else
Solution #1
posted on Aug 31, 2008
Somewhat Helpful)
welcomejee
Rank: Guru  Sony Expert
Rating: 89%, 3155 votes
Please check Input Voltage 110 ~ 240 volts AC at rear or bottm side of unit. If same is written there, its Auto Voltage Operatable and can be use on 220Volts.
Comments:
Aug 31, 2008
- I didn't said to find any switch there. There would be label with above information written on it. If label has info about Input voltage 110~240 volt ac, it can be plug in 220volt line.
Aug 31, 2008
- find info for working voltage on Model Number and Serial Number label.
Aug 31, 2008
- ok, Don't plug it in 220 volts.. use Step-Down Transformer having input 220 volt and output 110 volt to power up this unit.
If you plug it directly in 220volt ac, its power supply will blown and unit will dead immediately.
Aug 31, 2008
- Hi,please rate the solution as fixya..4 blue diamonds
Was this helpful?
Yes
No
Solution #2
posted on Jun 18, 2009
Not Rated)
jestoni
Rank: Apprentice
Rating: 0%, 0 votes
get a step down tranformer with a max. power of 500w 220 input 110 output. just plug your equipment at the transformer.
and that will work.
Was this helpful?
Yes
No
Solution #3
posted on Oct 23, 2008
Not Rated)
docofeagles
Rank: Apprentice
Rating: 0%, 0 votes
Get a 220 to 110 converter.
Was this helpful?
Yes
No
Popular Solutions for Sony DAV-BC150 System
Questions and Unsolved Problems for Sony DAV-BC150 System
Do you recommend Sony DAV-BC150 System?
Answer
Answer
My Sony DAV BC150 will play DVD's but not CD's. It was working fine, but we haven't tried it in a... (More)
Answer
I am getting static on the subwoffer channel. Is there an easy fix for this? The problem is not... (More)
Answer
I have a Sony DAV-BC150 home theater system I can start it up it comes on and then seconds later... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
