Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Pagefile.sys is blocked. It is being used by another application
When I scan the computer, the results show that this file is blocked. It cannot be opened. Since the computer is very slow I assume that this maybe the reason. Is there a possibility I can do something to improve this? Thanks,
Maria-Teresa Araneda
  • 102 Answers
Try to access file. or this file is password protected
Posted on Aug 31, 2008
Slow shutdown
Try to check-up control panel of your PC, I know your PC configured for automatic windows application update. also try to full scan(present anti-virus software) your PC system maybe same spyware, worms and virus inside on the operating system (OS) and other software desktop.
Please see screen shot picture below.
Oct 18, 2011 | Dell Inspiron 531s Desktop Computer
I want a shareware software to fix virtual memory. My laptop is too slow so i need something that will fix the virtual memory
The virtual memory is the Pagefile.sys in C:\
To defragment the pagefile, we first have to remove the pagefile, then defragment the machine, and finally recreate the pagefile. To do this, start by opening the System utility in Control Panel. (You may have to get there by clicking Performance and Maintenance from the Control Panel and then clicking System.) Then select the Advanced tab, click the Settings button under Performance, select the Advanced tab of Performance Options, and click Change to view your Virtual Memory settings:
Now select the No Paging File option and click Set. This will disable paging entirely and should also remove the pagefile (pagefile.sys) from the hard drive the next time you reboot your system.
If it doesn't do this, you can delete this file manually after rebooting. It's normally found in C:\
Reboot your machine, and when Windows comes up, use Disk Defragmenter to defragment the volume where your pagefile was previously (C: drive normally). Once your system is defragmented, open the Virtual Memory box again, and change the pagefile back to System Managed Size, OR set both the min and max to same size, 3 times your actual ram. This will help prevent the page file from becoming fragmented.
Then, reboot your machine again.
Note that one Gig is 1024 MB example: 3x1024=3072
If you find your pc still has issues, or the fragmentation gets worse, it likely you have malware or even virus on it that's creating the slowness issues. These should be cleaned out too.
Feb 10, 2011 | Dell Computers & Internet
Pagefile.sys problem
You will have separate pagefiles for each OS. You cannot use a single pagefile for multiple OS installs, they are unique to each OS.
Mar 23, 2010 | Microsoft Windows XP Professional SP2
Rootkit
Hello,first try to find the driver from device manager(right click to my computer,properties,hardware,device manager).Once you have open the device manager press on View and check Show hidden devices,your driver(virus) is on non plug and play drivers and with right click you can unistall it.But if is a root kid and a tought one it should have another file in your system to recreate it!So clean your windows temp files and internet temporary internet files(you can with a application or just right click to your disk,properties and click disk clenup).If you still can fix it
download HijackThis and in the main menu press do a system scan and save logfile.After open your logfile and give me the results
Good luck
Jan 22, 2010 | Internet Grisoft AVG Security Full...
How to scan to file or e-mail
If you select these options on your printer, you must have an application on your computer that will process the results of the scan.
You can scan to a file for processing of an application like photoshop. Your email program must be able to handle the file format you scan in.
In either case, you will be asked which application will be used to process the file or email attachment.
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Page file
Computers use the RAM of the computer to store the active programs, and perform other operating system functions. Obviously, there is a limit to how much RAM is available for this function. This is why Windows runs faster with more RAM installed.
Since Windows allows you to open multiple programs and switch between them, it is more efficient to "swap" inactive programs or parts of programs out of RAM, so a special disk files is created - "pagefile.sys".
Pagefile.sys is related to the "Virtual Memory" function of Windows.
You can see the pagefile setup by right clicking on My Computer, the go to Properties/Advanced/Performance/Advanced.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
WinXP SP2 performance problem (Compaq Evo N610c notebook PC)
i suggest to format your PC and install again your OS. some files affecting or viruses affecting the performance of your computer result to some memory dump.
Jan 16, 2008 | Microsoft Windows XP Professional With...
Gateway 7330GZ will not follow through at start up
At startup, hold down F8 key. select safe mode start. allow windows to guide you from there. if no-go, then repeat but choose dos prompt only, then insert a win 98 startup disk and run scan-disk on your drive. if no-go, in worst case, try to delete the pagefile.sys file from dos prompt (you may need to change file attributes from read-only and hidden and system to toggled-opposite-read, not hidden, not system). and repeat above steps
May 27, 2007 | Gateway 7330GZ (890552601318) PC Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
95 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
