SOURCE: My Hanns-G hw191d monitor quit coming on. The
First, flip the switch for your power surge protector, to see if that resolves. Then, test the monitor on another computer and see if it works. If the monitor still doesn't work, look for another one. Hope that helps.
SOURCE: i rebooted my computer which is running windows xp
You can adjust the screen resolution and this will affect the image size.
Go to Control Panel - Display - click on Settings tab, then adjust the screen resolution. Try 1024x768 first, and adjust up further as required.
SOURCE: Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
SOURCE: My 28' Hanns-G monitor flickers from center to bottom of screen
i think one of your cables are loose of worn out like vga try another vga see what happens ok;
SOURCE: Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
