Question about Epson PhotoPC 3100Z Digital Camera
Image Expert on Macintosh
I have a Macintosh with 64MB memory or less and I get "not enough memory" messages when I try to open a HyPict picture from Image Expert. What can I do?
    Master:
  • 542 Answers
Turn ON virtual memory or add more memory to the system. Allocate more memory to the application.
Posted on Sep 12, 2005
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
NOT ENOUGH VIDEO MEMORY - video ram required 64mb
You need to upgrade your video card to one with the required ram. What OS are you running?
Apr 04, 2009 | Adobe Photoshop 7.0 for PC
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
Cannot erase memory card
Try another memory card and see if you still have the problem. In case it will solve your problem - the existing memory card is defective and should be replaced. Let us know with your results and we will do our best to support you. Good luck !!
Jun 24, 2006 | Polaroid PhotoMax PDC 2350 Digital Camera
Does Hypict really help the resolution?
Hypict degrades image qulity a bit because it is interpolation. You can basically do the same thing in photoshop with similar results, I haven't tested this yet. What it does do is make a beter looking 11x14 print than using the 1200x1600 setting, with no after shot manipulation by the user, so if you knew you wanted the image bigger for some reason, and didn't want to manipulate it later you would do this.
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Can I use the IAS with video clips or TIFF formatted pictures?
No. IAS only supports pictures with standard, fine, superfine and Hypict, JPeg formatted pictures.
Sep 12, 2005 | Epson PhotoPC 3100Z Digital Camera
Why does it take so long to take a picture?
You may be pressing the shutter all the way down at once. This forces the camera to focus, make exposure adjustments, and capture the image all at once. By pressing the shutter button partially to focus, then the rest of the way to capture the image, your camera can process pictures more quickly. If you are taking a picture in Uncompressed Tiff mode, the camera takes longer to process the image. Tiff images create large files and can take approximately 32 seconds to process. If you are trying to capture large, high quality images that you can print, try setting the camera to HyPict mode instead of Tiff mode.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Epson PhotoPC 3100Z Digital Camera Logo
32 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Thomas Stauber
Thomas Stauber
Tony Parsons
Tony Parsons
Are you an Epson Camera Expert? Answer questions, earn points and help others
