Question about Samson AirLine Guitar - Wireless System Microphone
SAMSON STAGE 5 (BASS)
Hi.
Actually my problem is with Stage 5 wireless system; all of a sudden the signal sounds overloaded but it doesn't reach even half the range. I used to play with a Music man Sting ray 5 and a Behringer Ultrabass BX450H and everything was ok. What has happened? What can I do?
Thancks a lot for every help you can give me.
Lino, Italy.
I have the same prob but i use concert 77
Posted on Apr 04, 2010
How do I get a larger coverage signal area from the clear choice smart rg wireless modem/ router
Place it in the middle of the room. All walls, special concrete, will degrade the signal. But what also makes WiFi degrade is other modems close by. Even if they use another "channel" The best results can be achieved with 2 band modems. 2,4 GHz and 5 GHz. The 5 GZH is not yet used that much and although the reach is less, the chance other users will degrade your signal is smaller.
Jan 20, 2015 | Computers & Internet
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
Samsung refrigerator error code 8E
8E = OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Nov 23, 2012 | Samsung RS265TDRS Side by Side...
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Belkin N1 Router PROBLEMS
Wireless routers all use the same frequencies either in the 2.4gHz range for 802.11b, g, or n, and 5.4gHz for 802.11a networks. These frequencies both have a VERY low penetration (it's ability to go through objects) the quarter wavelength for a 2.4gHz signal is approx. half an inch. So that means anything that size will act as an antenna and absorb some of your signal.
Chances are you floors are made of concrete and this makes almost an impenetrable barrier for wireless. Top this off with the fact that the 2.4gHz spectrum is so over saturated with noise from other devices, and the fact that there are truly on 3 NON-overlapping channels that can be used, and that 802.11n will use 2 radios on 2 non-overlapping frequencies, and you now have a pretty good idea of why this setup will no work between floors.
I used to engineer and implement wireless networks for college campuses and large offices, and even in the best of conditions we would typically set AP's on 100ft centers. Wireless networks have to wait on the slowest connection to finish with transmission before they can go on servicing other connections. So one slow connection on the edge of your coverage range could actually have every adverse affect on everyone attached to that AP.
Some food for thought. I recommed a second AP hardwared to the LAN on the second floor at the very least, and I strongly recommend staying away from 802.11n unless you know there are no other wireless LANs in the area.
Feb 18, 2009 | Belkin (F5D5231-4) Router
Choosing a stronger router
You can get this one its WRT300N this a router that uses the latest wireless N technology which means a wider range and faster speed but using this router in order for you ro use the wireless N technology you may need a wireless N adapter also on your computers.
But if you want since you already have a existing wireless network juts get a wireless range expander to repeat the signal of the router so it will reach your XBOX this is the model WRE54G.
May 16, 2008 | Linksys Wireless-G WRT54G Router
Message on screen 8E, Motor won't start on spin cycle. Model no Q1435(C/S/V)
This is what I found:
11. OVER CURRENT ERROR - Display shows 8E .
- IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
IPM : Integrated power module. , IPM controls motor.
- If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
the motor stops immediately. However, during dehydrating stage the signal is to be sensed
when the number of signal is more than 6 for 500ms.
- During Cleansing or Rinsing
When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
If the stopping of the motor working is happens in one direction ten times,
- During dehydrating
When the overload is sensed, the motor stops to work at once and then feeds back to the initial
When the feed back is continuously happened 2 times, "8E" Error is displayed
During the dehydrating unbalance sensing, No error happens by overload sensing.
-Power S/W Off can clear the overload error.
in short: imbalance problem
In a german forum one guy solved the problem by replacing the motor electronics. I am currently experiencing the same problem. I keep you posted.
May 08, 2008 | Washing Machines
Samson AirLine Guitar - Wireless System Microphone Logo
186 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
