Whirlpool AWO/D 8708 error code F13
I have a whirlpool AWO/D 8708 and got error code f13, i followed the instructions by holding the drain/eset button for 3 seconds bt nothing worked.
so i turned the washer of by the mains, left it fr about 10 minutes, then went back to turn it on, to find it will no longer even power up.
cannot fnd any help at all on this product online, so i hope one of you guys can help me as i have a little one on way and need it!
5 Suggested Answers
  • 1294 Answers
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Posted on Sep 03, 2007
blueextc3221
  • 15935 Answers
SOURCE: Error code F13 is showing
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Got a whirlpool washing machine the door wont open
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Posted on Sep 21, 2010
SOURCE: I have a whirlpool 6th
f13 is a problem with the door lock, I have the same machine and it takes 4 minutes for the door latch to open and if it dont in the 4 minutes F13 comes up and the machine will go off and not start again.
Posted on Oct 21, 2010
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
Im getting F13 on my oven display when trying to use it?
Sabrina I do not see an F13 Error Code for Whirlpool, Try unplugging oven for a few minutes and then plug or switch power back on from breaker and it should reset. Also send the exact model number located inside your bottom drawer door or oven door. Here are all the codes listed for Whirlpool=> Whirlpool Fault Codes You also can find your user manual here=> Whirlpool User Manuals and model number Locator's here=> Model Number Locator's I have spent a lot of time trying to help and will be happy to assist you if you have more questions, Thanks, Sea Breeze
May 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Cant reset my f13 fault and wen i power on it takes its take to lite front panel up
Hi again,
Whirlpool AWO 'F13' decodes as 'dispenser circuit failure'. If you have tried switching off and back on again and it is still there I suspect it means that you will have to call an engineer. Sorry ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
I have a F13 fault that wont reset on a AWOE9759. I do not know what a F13 fault is but i have tried what it says to do in the manual. Please help.
F13 Error = Dispenser circuit error
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Replace failed component.
Dec 26, 2010 | Whirlpool Washing Machines
My AWOE8748 had a fault code F13. It has now switched itself completely off.
F13 indicates "Dispenser Circuit Error" in your washer.If the dispenser motor is not able to be driven to it's proper position this error code appears.Check mechanical linkage from dispenser motor to the top of the dispenser. The wire harness connections to the dispenser motor and Central Control Unit (CCU) would have been faulty so check for those.Also do a final check on dispenser motor.
Thank you !!
Jun 20, 2010 | Whirlpool AWOE8748 Front Load Washer
My whirlpool washing machine keeps saying f13 whats wrong and how do i fix it
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
Fault codes f 13 Whirlpool Washing Machine AWO/D 5716
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
Jan 29, 2009 | Washing Machines
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
Washing Machines Logo
342 people viewed this question
Top Washing Machines Experts
