Question about Gateway GT5220 PC Desktop
Can not get internet on gateway e-series regular ethernet card won't fit
Can not get ethernet on my gateway e-series computer. Is connection different from regular computers. There is an ethernet connection, but I don't see a card.
  • reereelee Sep 03, 2008
    no internet connection, replaced ethernet card and it isn't recognizing card. Loaded installation disk successfully but internet is still not working.... what now?
  • 95 Answers
When you plug that wire in you should see a green light, if not then your ethernt adapter is probably bad or there is no signal coming from your wire
Posted on Sep 01, 2008
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
I have a Gateway T-series (Model:W350A) laptop. I just reinstalled Windows Vista and now the computer is not recognizing the built in wireless card. How do I get it to recognize it? Or how do I install the...
Plug in an ethernet cable into your ethernet card port on the left hand side of your laptop. When it connects to the internet click on the Windows update icon in the system tray. It should show you a Realtek Wireless RTL8187b wireless adapter driver update. Install it, you may need to reboot, but in any case you will have wireless networks available to you and you can pull out the ethernet cable. Good luck.
Dec 30, 2009 | Gateway M305CRV Notebook
Gateway computer and ether net card will not plug in
There have been several varients of buss slots over the years from Vesa to ISA8bit ISA16bit EISA 32bit and PCI32 and PCI64 and more recently the PCIE and PCIE16 bus slots.
at a guess I would say that the card yrom your old gateway is a VESA or ISA16 card and the newer gateway is a PCI
the way to Identify an ISA card is to look at the edge connector that plugs into the motherboard, the ISA 8bit will have 31 sections to it the 16bit varient than has an aditional 18 connects on a sepparate section. this connection is much lager than the PCI bus slot even though PCI has over 50 connectors. VESA cards are lager again and have 3 sections to their edge connectors - the boards are not interchangeable.
Jul 07, 2009 | Gateway GT5220 PC Desktop
Ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Apr 14, 2009 | Gateway MT3705 Notebook
Ethernal Controller Problem
click start
click connect to
show all connections
look to see if lan or high speed internet shows connection.
If enabled and not working look on back of computer to see green light from ethernet plug.
if no green light try different ethernet cable, if that doesn't help replace ethernet card less than $20
Mark
if you need more let me know
Apr 11, 2009 | Gateway GT5220 PC Desktop
Ethernet card
hi there. The ethernet card is an interface that allows your computer to be connected to a LAN (Local area network) and to a Cable/Dsl modem to be on the internet. The connector looks bigger than the one of a regular telephone jack (it's actually double). If you don't have the ethernet card you can't go on the internet or on a LAN.
From the back of the modem or router you should connect a cable to your ethernet card of yor computer. Only after you did that you can try to connect to the internet.
Let me know, or be more specific.
thanks
Mar 30, 2009 | Dell Computers & Internet
Ethernet cable does not fit into computer
You might be trying to plug the ethernet cable into the modem. This is smaller than the ethernet connectionbut looks the same. If there is no ethernet connection on the computer you might need to have a NIC card install.
Jun 08, 2008 | Computers & Internet
Internet connection
There are 3 ways to connect to the internet. Using a modem with a phone line, an ethernet cable that is hooked up to a high speed internet connection or using wireless. If the laptop does not have a modem, it may have wireless or an ethernet port. Ethernet is slightly larger than a phone jack. If there is wireless there should be a button to turn it on and off somewhere along the top of the laptop where the keyboard is. You could also put get type of those connections on a PCMCIA card which fits into the credit card like slots on the side.
Jun 09, 2007 | Panasonic Toughbook 27 Notebook
Gateway GT5220 PC Desktop Logo
155 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
