Question about 3M S10 Multimedia Projector
Changing lamp and resetting timer
I've changed the lamp but i'm still getting a message to change the lamp when i turn the projector on, also i cannot reset the lamp and filter timers?
If it is a Viewsonic Projector, hold reset on the remote for 3 seconds!!!!! (*.:.*)
Posted on Feb 15, 2009
Take out the power cord and put it back then hold the help option on the remote for 20 to 30 seconds to resert the lamp. Then you can switch it on.
Posted on Oct 23, 2008
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
    hi
    this lamp has a small lamp pcb with a chip on it.
    have u change the complete module or have just changed the bulb.
    if you have just changed the bulb then u have to replace the small fuse on the chip.
    this should help to reset the lamp timer!
    Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
    How to reset the panasonic PT-L702ES LCD PROJECTOR after changing it bulb ET-LA702
    How to reset timer on PT-L702E LCD PROJECTOR:1. Power on the projector and go into the menu
    2. Go to OPTIONS > LAMP TIMER
    3. Press and Hold ENTER for at least 2sec - message will change to something like 'Power Off to reset timer'
    4. Press POWER to power off projector
    5. Power projector back on
    The timer has now been reset to Zero Hours
    Enjoy!
    Sep 21, 2011 | Teac Panasonic Etla702 Replacement Bulb (...
    Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
    The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    When I turn on my Christie DS30-projector, I get a message telling me that the lamp only has 10% left, even though I recently changed it. Is there a way to fix this? It clearly isn't at 10%.
    You probably didn't reset the lamp timer after changing the lamp. All I could find in the user's manual is this: In the "utilities" sub menu, reset the lamp timer.
    Jan 26, 2011 | Christie DS30 Multimedia Projector
    Can't start infocus sp7200 after changing lamp.
    The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
    Cheers
    Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
    Projector
    Go into the projector menu, OPTION and then select LAMP TIME.
    May 30, 2008 | 3M Projector lamp Projector Lamp
    Lamp timer reset
    Found in the owners manual.
    It's important to reset the Lamp timer after replacing the lamp since the Lamp timer
    will trigger the warning message. This can be done in Standby mode by pressing the
    following sequence within 5 sec.
    RESET, Left Arrow Key, right Arrow Key, ENTER.
    This is also explained in the operation manual of the Lamp.
    Jan 25, 2008 | Sony VPL PX11 Multimedia Projector
    Reset the bulb
    1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
    Jan 12, 2008 | LG RD-JT91 Multimedia Projector
    3M S10 Multimedia Projector Logo
    479 people viewed this question
    Top 3M Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
