Question about Proview PT 15.1" LCD Monitor
Proview monitor Keeps blacking out every 14 sec
  • 4 Answers
Proview known to have problems with failing capacitors in the power supply, not too hard to do for a few pounds worth of new caps. and a soldering iron.
Posted on Nov 21, 2008
My proview monitor stays on for 10 sec then goes black. but i can faintly see my page.
This indicates an inverter board failure, caused by bad capacitors that sometimes bulge at the top showing that they are open, an attempt can be made to repair or replace the board.
Mar 05, 2011 | Proview PL926WBi 19" LCD Monitor
Where can I buy a power cord for my Proview PL456s 14 in. Flat Panel LCD Monitor?
Can you supply a picture of the connection on the back of the monitor? Try to make it high quality and put a scale, ruler or dime near the connector to give proper scale/size and I will research it for you.
Dec 01, 2010 | Proview PL456s 14" Flat Panel LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor problem
I bought Same Monitor Dec. '06 and Jus last week It faded to black and then now doesn't power on. my protection plan sent me a new one that powered on for like 20 secs. So now I have another one coming. I also knows its not my PC cuz I'm using a monitor right now. I think Proview and Circuit City Sucks
Jan 21, 2008 | Proview PL926WBi 19" LCD Monitor
Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Jan 18, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor turns on then off.
Jan 11, 2008 | Proview PL926WBi 19" LCD Monitor
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Screen goes dark
it indictes problem with ur crt tube in monitir
Dec 02, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PT 15.1" LCD Monitor Logo
167 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
