Question about Epson PhotoPC 3100Z Digital Camera
Why don't the colors in my picture look right?
    Master:
  • 542 Answers
When you take pictures under certain artificial lighting conditions, the colors may be slightly distorted. You can use your Image Expert software to adjust the colors.
Posted on Sep 12, 2005
When I download pictures from my Xsi, I notice that half of the pics are named "IMG_4983.JPG", whil the other half are named "_MG_4984.JPG"...i.e. The first character "I" is replaced an underscore "_". ...
Don,
This has to do with the color space that your camera is shooting in. Somehow this setting must have been inadvertently changed in your camera. The color Space that you are currently shooting in is called Adobe RGB (_MG_4984.JPG) what you want to shoot in so that you don't have to rename your files is sRGB (IMG_4984.JPG). Adobe RGB is used for commercial Printing and other such things. Now then how to change it back:
1) Push menu button
2) scroll over to the second tab from the right (It's the one that looks like a camera with 2 stars to the right kinda like a colon)
3) Under the tab select Color Space then push the set button
4) select the desired color space which for you is the sRGB then press the set button.
5) shoot lots of pictures :-) if you are still confused try reading the instructions for your camera since you were to lazy to do so the first time around b/c this is where I got the answer to your question. Perhaps try rereading page 87. If you don't have a manual then ignore the last comment and go here for a copy
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_rebel_xsi#BrochuresAndManuals
Sep 29, 2013 | Canon EOS Rebel XSi Digital Camera
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
My Samsung HLP6163W started making a loud buzzing sound and the picture is distorted. I've read around and have come up with two possible solutions: replacing the lamp or replacing the color wheel. ...
100% this tv problems it is the tv colors wheel it is defective require replacing.The loud tv buzzing noises sounds are the sounds came from the tv wharp colors wheel it is spinning out control wildly and off of it motor axis and by hitting it to the wall of it steel box holding it.The tv distorted colors pictures are came from out of the reflections of a badly worn out of the tv colors wheel.
Jul 08, 2011 | Samsung HLP6163W 61" Rear Projection...
The pictur freezes to balck and white.
Tv have a colors wheel design into it.Tv make alots of noises like grinding,humming,buzzing or pictures freezes or lost colors or flashes black&white flashes within the pictures.The tv colors wheel it is dying and the colors disc is it warping and not spinning correctly inside it motor walls axis anymore.The tv colors wheel must be replaced.The tv colors wheel sit way back of the tv and have to take out alot mechanical parts out before even can come to it and change it.If u have no mechanical skills.Don't attemp change the tv colors wheel by ur self.Hire a tv tech.person to change it.
Jun 30, 2011 | Samsung HLN617W 61" Rear Projection HDTV
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
I have a 1997 Aerostar and would like to wire for trailer lights. I opened the panel on the left side just in front of the tail lights and found a couple wiring receptacles. Are these for trailer...
if they have color coded wires that are brown,green,yellow and black then its possible.but i don`t think so.you can buy a trailer wire adapter that just plugs into the car factory wiring so you don`t have to splice(solder) the wires into the car wiring and it will show you the area for the connection and picture.if you don`t want to go that route then the tail light wires colors are brown.the left signal color is yellow and the right is green and the ground wire on the car is black but on the trailer wire harness it is white.
Apr 12, 2011 | Ford Aerostar Cars & Trucks
Background
Hi Adrien, the easiest way to set a picture as a Windows background is to open the picture in your web browser and right click on it. A menu box should appear, about half way down you should see an option labeled *Set as Background*. Left click on that option and Windows will automatically use that picture as you background image and tile it to fill your entire desktop. Alternatively if you have Windows XP and use the Windows Picture and Fax Viewer program to display the picture the process is the same except when you right click on the picture the selection will be *Set as Desktop Background*. When you select that option it will do the same thing. If you don?t like the tiled effect right click on the desktop and select properties from the popup menu. In the display properties box that appears click on the Desktop tab, and in the lower right hand corner you will see a field labeled *Position*. Left click on the pull down arrow and select center or stretch, depending on what effect you want. Let us know if you need any other help and don?t forget to rate the posting.
Jan 03, 2007 | Dell Inspiron 1150 Notebook
Epson PhotoPC 3100Z Digital Camera Logo
113 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Thomas Stauber
Thomas Stauber
Tony Parsons
Tony Parsons
Are you an Epson Camera Expert? Answer questions, earn points and help others
