Question about Singer CE-100 Futura Computerized Sewing Machine
Bobbin Casing - CE150
I can not seem to get the bobbin casing back into the machine properly. My problem started with the thread building up under and around the bobbin, I had to take out the casing to clear the thread, now I can not get the casing back in. Please I need your help ASAP - I promised thsse shirts by 1:00 today. Is there a website that offers a service manual download for this machine?
  • GirlyGirlBow Sep 01, 2008
    Same problem- I took the casing out and thought I got it back in correctly, but now the problem is worse, the top thread catches on the casing and jams every time. I made sure that the projection is positioned against the spring as the manual says. Looking for help too.
  • SewPerfect Sep 01, 2008
    Thank you for the help. The link at the Singer site is not working, but I will keep working with that. After doing a lot research yesterday I learned the major importance in maintaining this machine regularly. My husband went in and found some thread that I was unable to see from the top. Once he cleaned out the wayward thread and oiled the machine I was good to go again. This is a great machine but don't learn the hard way like I have, clean and oil your machine after every big project.
Hi, I have one Futura GE-150, why the bobbin will not automatically stop when completely filled.
Posted on Apr 14, 2009
  • 64 Answers
There is a website for support (, but together with your software you should already have that manual and other help materials, check under menu section Help.
Posted on Aug 31, 2008
Upper thread is not catching bobbin thread
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
Jul 24, 2013 | Sewing Machines
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
I own a "Lena" machine
Make sure your feeddogs are up. That is the little jagged looking plate under the pressure foot. There should be a setting on your machine that will move it up and down.
If they are up then the bobbin is not in correctly. If it is a normal round bobbin that fits in a bobbin case, hold the bobbin in front of you so that the thread end is on top and the thread is going away from you, and slide it into the bobbin case. Feed the thread through the right openings in the bobbin case. When you pull the thread end the bobbin should turn clockwise.
Never hand-wind bobbins. Instead, use the accompanying bobbin winder which is attached to most machines,bobbin casings must be oiled regularly to prevent problems with the bobbin turning properly. The bobbin, when inserted properly into the bobbin casing, should spin counter-clockwise when thread is pulled.
Check the way your machine is threaded. Completely un-thread your sewing machine and re-thread it. Remember to always thread your machine with the presser foot up.
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
Always watch for bobbin wear, especially on the plastic type of bobbins. If the edges of the plastic are showing abrasions, the size of the bobbin has changed and may be the culprit. Although the size change is minute, it allows the bobbin to wobble in the case and changes the tension.
Dec 19, 2010 | Husqvarna Sewing Machines
Thread on bobbin looping
Sounds like you need to adjust the bobbin casing tension (tighten the little screw on the bobbin case). I would also oil the face of the bobbin casing so that the thread wont snag or tug on it at all.
Jul 15, 2010 | Kenmore Sewing Machines
The casing that the bobbin sits in is out how do I put it back in. The Bobbin holder below the tension feet is out and so is the bobbin how do I set it back in with out undoing the two latches on the side...
put the bobbin in its case then pull some thread out and pass it thru the bobbin case slot and under the tension spring .. put the bobbin and case over the shaft that is in the main unit .. the open side of the case goes in first .. make sure the bobbin doesnt fall out .. rotate the bobbin case until its finger lines up with the notch in the main case .. the bobbin case should latch in place on the shaft notch .. place the top thread under and to the back of the pressure foot then turn the machine one turn .. that will loop the top thread around the bottom (bobbin) thread ... now use a card or screwdriver to push both threads from under the pressure foot toward the back of the machine ..
Jun 21, 2010 | Singer 8280 Mechanical Sewing Machine
I have a Futura CE150 and error 19 keeps popping up but nothing seems to be wrong with the thread or bobbin thread
Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Bernette sewing machine making a mess of thread on back of fabric
I once heard from a great sewing instructor that if the problem is on the back of the fabric then it is a spool to needle problem.... if the problem is on the top of the fabric, then it is a bobbin problem. Check your machine for dust and stray threads. Check your bobbin casing for dust and stray threads.
Dec 14, 2008 | Sewing Machines
Singer CE-100 Futura Computerized Sewing Machine Logo
196 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
