Question about ASUS P5LD2-VM Motherboard
Help - no-one can fix my PC - no desktop, icons, task bar
I had 3 trojans on my PC which were picked up by AVG. In my rush to get them off my PC, I downloaded Combofix but accidentally stopped it after step 7. I am left with no taskbar or desktop and have to use task manager to start an application - some of which don't work such as Windows Explorer. Having tried to use the recovery disk for XP, it comes up with the error "Viamraid.sys" not found. I have photos on my D drive which I don't want to lose and no-one appears to know how to help.
    President:
  • 2,351 Answers
Hi hiltona, the error" viamraid.sys" not found is located (Or was located) in, C:\Windows\System32\drivers. (It is the VIA RAID driver for win XP, 2000 & 2003). The VIA file is most likely just one of many files in windows that are corrupt, not to mention many of windows regestry files. It would be impossible to fix all these windows files & registry keys.
Can I suggest that you remove your hard disk drives & connect them into a friends PC if at all possible. One at a time. (First your C:\ drive than your D:\ drive).
If your drives are SATA's they will default as slave drives. If your drives are IDE you'll need to set drive's jumper to be seen as a slave drive. What you have to gain by doing this.
1. Hopefully the PC your placing your drive into will have a virus scanner running & up to date, which will clean the Trojans/viruses from your C:\ drive.
2. You'll be able to copy you're personal data to a CD or DVD if the PC has a CD/DVD writer in it. (See the list of folders you want to write to a CD writer below).
3. Your D:\ drive will be cleaned & you will not loose any data other than files that may have been infected.
4. Taking it to a repair shop will cost you $$ & most places do not back up your data. (Unless you pay for it)!
Pull the memory from your own system when you remove the hard disk drives. Removing the memory will clear any memory resident virus. Once your primary drive has been cleaned re-install it into your PC & incert your memory.
Install windows. (Fresh install is recommended & format because many windows system32 files will be trashed). Once windows is installed, register with MS & than update your system through windows update service. Download & install AGV for free from this link: http://free.avg.com/ww.download?prd=afe
Run a full system scan. (Play it safe). Next is the list of folders you'll want to burn to a CD writer after your C:\ drive has been cleaned.
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you have installed.
Once windows has beed installed you can copy these back to your C:\ drive & over write the folder.
Good luck hiltona!
If you run into trouble just let me know.
Mike
Posted on Sep 01, 2008
Why do my icons don't appear in the lower right, I would like to reinstall day date calander and time
It is not very obvious. The bar at the bottom of screen is your 'Task Bar'
1. Find an empty part of your Task Bar and Right Click on it
2. Select Properties
3. Near the bottom of the menu in 'Notification Area' tick Box 'Show clock'
While you are there, it shows all icons that are on your Task Bar. If empty find the 'Hide Tasks' box and untick
4. Tick Apply and OK
May 30, 2014 | Lenovo Computers & Internet
My computer started up normally, then nothing.
It sounds like you have a virus riddled computer as well as no Anti virus protection either.
Try and get your desktop back this way >>>>>
Start task manager, in the top right hand corner of the window you will see File, click on that. Where it say's new task (Run), click on that and type in the box explorer and then hit the enter key.
Hopefully your desktop icons and task bar will return.
If they do return you will need to obtain some anti virus software.
You can get AVG 9 Free here >>>>>>>>
http://download.cnet.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?part=dl-10044820&subj=dl&tag=button&cdlPid=11014801
Download and install this excellent free software and then perform a deep scan of the system for any and all viruses, malware and spyware.
If you can't get the desktop icons to return post back here straight away and tell me what operating system you are using, like XP, Win 2000/98 for example.
Good luck.
Nov 14, 2009 | HP Computers & Internet
My laptop's (Toshiba Satellite A105-S361)desktop doesn't bring the desktop icons and the task bar after I loaded AVG 9 antivirus software. Why is that? Would you mind give me a solution, pls?
The desktop icons and the task bar would generally dissappear if you have a virus on the PC. However, sometimes improper software installations may cause undesired results like we have right now. Instead of trying uninstalling anything, try restoring the system to a previous point using system restore.
regards
Sandeep
Oct 20, 2009 | Toshiba Satellite A105-S361: Satellite...
Black task bars
I would recommend you to install a application called TuneUp utilities which is a awesome software to restore your taskbars, broken desktops and missing files in windows operating system. Dont worry all your icons would be restored.
Sep 18, 2009 | HP Compaq FS7600 17" CRT Monitor
Lost connection
If your computer is working ok can you press Ctrl+Esc together to open the start menu and is all your programs listed. if so then go to settings - control panel - click on display - find your advanced option and untick the option for displaying the desktop as a URL...
you can also try simply right clicking on the desktop and tick the option the see all icons but that will not show your tast bar only your icons.
Feb 20, 2009 | Acer Aspire One AOA150-1570 Notebook PC
On bootup checks, stops at 02FC Main and second fans failed. Black screen with bootup messages. ?Has the MA7 even got two fans? How to correct.
Sounds like you may have a virus or trojan of some sort. They are hard to get rid of but try downloading avg 8.0 it's free and picks up most trojans and viruses. If you get a black screen with boot message just hit control alt delete together and your pc should bypass this problem and allow you in. If avg doesn't pick up trojan or virus it maybe a software failure but it will usually tell you whats missing and if pc was working fine and just started this it is most likely a virus or trojan
Jul 26, 2008 | Gateway Computers & Internet
Problem with viruses
  1. Go up on the net.
  2. right click on the grey AVG icon on the task bar
  3. select look for updates
  4. when the update box comes up on the desktop, select internet.
Mar 25, 2008 | Microsoft Windows XP Professional With...
Icons and Start Bar
right click on taskbar
go to properties
uncheck the option that says auto hide the taskbar
also uncheck hide inactive icons
click apply
click ok
Jan 22, 2008 | Toshiba Satellite A105 Notebook
No task bar or icons appearing on screen
the easiest option will be to do a system restore to before the outage; Start/All programmes>accessories>System Tools>System Restore. Then choose restore my computer to previous settings, then choose a date that is not greyed out. Hope this sorts it Please rate solution
Nov 20, 2006 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
ASUS P5LD2-VM Motherboard Logo
133 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
