Question about Epson PhotoPC 3100Z Digital Camera
The LCD image is dark or nothing appears on the LCD screen.
    Master:
  • 542 Answers
The camera may have shut off automatically. Press the shutter button halfway down or turn the camera Off and then back On to View or Play mode. Make sure the lens cover is removed. Check your batteries and make sure they are installed correctly. Recharge or replace the batteries if necessary. Make sure the dial is set to LCD mode.
Posted on Sep 12, 2005
SOURCE:
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Lens screen stuck open and no image on LCD view screen.
It is jamming, the only really fix is to have it repaired, that costs a lot and it is sometimes better to just replace the camera.
Mar 15, 2014 | Sony Video Cameras
Very dim LED screen on Acer One D255E netbook
The laptop video circuits are good and the fault lies with the display or the power feeding the display.
Go for the display since they do go bad.
Aug 25, 2017 | Computers & Internet
The image is blurry (ghosting) and dark.
the tab bonds on the lcd panel where they attach to the Drive circuits above the TCON samsung is famous for bad flex tab bonds. Does the screen appear llike its in slow motion and double immages in that half of the screen as well as appear to have dark bands aross the screen? If so its probably the flex tab bonds.
Mar 30, 2012 | Samsung LN40A630 40 in. LCD TV
I am using a sony DSC-T1, when in the camera mode the screen is dark except for the numbers and dots that appear for camera operations. I can not take a picture of anything. I can review photos, when I...
CCD imager chip is defective in your Sony DSC-T1 camera that is why you see no image in lcd screen.
Replace ccd imager chip to fix the camera problem. Local camera repair shop will help you to replace bad part if you have no experience of electronics stuff repair.
Aug 15, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Well i dont really know but when i star over the cam the screen is black and it doesn't appear nothing so just a leyend that says access when I take off the memory stick said turn on again the camera just...
Looks like a CCD image sensor failure a common fault in digicams these days. Point the camera somewhere and blindly take a shot. Open the image on your computer and see if it appears all dark. If it does then its an image sensor failure. On the contrary if the image appears properly then your LCD screen is the culprit.
Jun 13, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Problem with dark LCD screen and accessing the the LCD ribbon that I think is loose
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 10, 2009 | HP Pavilion dv1010us Notebook
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Epson PhotoPC 3100Z Digital Camera Logo
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
