Question about Samsung Cell Phones
Can not start up bluetooth - Samsung Cell Phones
    Brigadier General:
  • 7,752 Answers
Try a hard reset *2767*3855#
Posted on Aug 31, 2008
Having a problem pairing my iPhone 6 to my Tx-sr333 receiver. Iphone just grinds and can't find Bluetooth.
Hi Don,
Pairing is necessary when using the Bluetooth-enabled
device for the first time. Before starting the procedure, learn
how to enable the Bluetooth setting function and to connect
with other devices on the Bluetooth-enabled device.
1. Press BLUETOOTH on the remote controller.
The unit enters the pairing mode and the BLUETOOTH
indicator starts flashing.
2. While the BLUETOOTH indicator is flashing,
complete connection on the Bluetooth-enabled
device in the nearby area within about 2 minutes.
If the name of this unit is displayed on the Bluetoothenabled
device's display, select this unit. Paring will end
after a short time.
???? If a password is requested, enter "0000".
???? When connecting the unit to any other Bluetoothenabled
device, start pairing by pressing and holding
BLUETOOTH until the BLUETOOTH indicator starts
flashing. This unit can store the data of up to ten
paired devices, Thanks, JT
Mar 09, 2015 | Onkyo Audio Players & Recorders
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
Bluetooth not visible
sleep computer and start . your bluetooth is start now and show at notification aria
May 31, 2013 | Acer Computers & Internet
Bluetooth? How? Where?
Activate the Bluetooth functions of your Compaq laptop to connect your computer to external devices such as mice, keyboards and smartphones without the aid of a wire. Bluetooth technology allows devices from different manufacturers to exchange data, communicate and share files despite differences in operating software. Bluetooth antennae can cause a significant battery drain, so they are usually turned off by default. Turn on your Bluetooth to start searching for available devices in range of your computer.
Click "Start" and type "wireless" into the "Start Search" field. Click the "HP Wireless Assistant" icon in the list of results. Click the "Turn ON" button in the "Bluetooth" section to activate the Bluetooth antenna for your Compaq laptop.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065493&lc=en&dlc=en&cc=us&product=434626 - DeviceOn
Jan 20, 2013 | Compaq Presario CQ57-339WM
Bluetooth starts automatically with windows
download CC Cleaner and go in to the startup and turn off Bluetooth
Nov 02, 2012 | Computers & Internet
I have a laptop of Toshiba satellite A135-S4677, in its Programs & features, it shows that it has Bluetooth installed in it but when i shearch it in the start engine it shows me its installation and...
Is the bluetooth internal in the laptop? You could go into device manager and update its driver. I bought a tiny plug in bluetooth usb thing which does the job as my laptop is too old to have bluetooth inside it.
Start button/Control panel/Device manager IF you are talking Windows.
And did you have a disc for the bluetooth?
Otherwise go to the makers website and download latest drivers to install.
Nov 01, 2017 | Computers & Internet
Want to hook uo bluetooth
First switch on bluetooth (settings---bluetooth).
Start > Settings > Communications and Add new Bluetooth headset. htc will search bluetooth headsets and find it. it will ask you to enter bluetooth passcode, usually it is 0000. then finished and you have paired Bluetooth headset with HTC
Mar 26, 2010 | HTC Cell Phones
I got a new bluetooth for my Samsung Black Jack ll. How do I get the old bluetooth off my phone so it will accept the new bluetooth?
Start > Settings > Connections > Bluetooth > Bluetooth
Highlight your Bluetooth device
Open Menu and select Delete
If this helps please vote for my answer.
Sep 13, 2009 | Samsung BlackJack II Smartphone
How to start bluetooth in my lenovo laptop?
i haven't any bluetooth confuguration in my laptop so what can i do ?
Apr 06, 2009 | Lenovo 3000 N100 Notebook
Bluetooth
This model should be Bluetooth equipped
To verify you can click on:
Start>control panel
In the pane that opens up one of the first option that comes up should be Bluetooth. If it is there then you are equiped. Also an easy way is to check especially if running Vista, click Start then in the search bar at the bottom of the start meni type Bluetooth.
Nov 12, 2008 | Acer Aspire 5520-5908 Notebook
Cell Phones Logo
89 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
