How do I retain the shutter sound, but get rid of the chime when the
menu button is pressed? Turning the sound off turns everything off !
I'm sure I managed this some time ago, but cant remember how !
To remove the hourly alarm (or 'chime'), try this :-
Press and hold the RESET button and then press MODE. If you want hourly chime ON - all the days will be displayed, press MODE button again to switch OFF the chime - all the DAYS will disappear.
try this
Think of the top buttons from left to right as A & B and the bottom buttons from left to right as C & D. The way to turn the chime off and on is by holding the C & D Buttons simatainiously and the pressing the B button. This will allow you to turn the Hourly Chime Off and On. When you see the digital chime pattern in the display the chime is on. When no pattern is shown the chime is off. Hope this helps the ton of people who have purchased these watches & either did not have instructions with or lost them. This perticular watch has been annoying the whole household for quite sometime and has now been put to rest..lol
ATTENTION:You MUST HAVE one working remote to add one more to the system. 1. Press LOCK button 5 times at 2 second intervals to resynchronize remote. 2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10 seconds. 4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then press the PANIC button ( on the programmed remote ) for 1 second and release both buttons. A chime will sound to indicate that the remote programming mode has been entered ( allow 3 seconds for chime to sound ). 5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons simultaneously then press and release just the UNLOCK button on the same remote. A chime will sound indicating the remote has been programmed. Press and release the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on each new remote you wish to program at this time. A chime will sound afer each additional remote is programmed. 6. Turn the ignition OFF and remove key. 7. Test Remotes.
Yes there is.
1.
Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
2.
Turn ignition to run position. (Allow ignition chimes to stop).
3.
Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4.
Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5.
Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6.
Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
Daimier Chrysler North American Remote Keyless Entry Programming procedures
Program Method A (Customer Program Method)
1. Press (LOCK) button 5 times at 2 second Intervals to resynchronize
transmitter, Attempt to function transmitter, If working as designed discontinue
programming.
2. Turn ignition to run position, (Allow Ignition chimes
to stop).
3. Using any original (working )transmitter, press the [UNLOCK]
4. Within the specified 4 to l0 seconds, continue pressing
chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for
6. Press and release any button an the same transmitter
NOTE.- (FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP #6 FOR THE FIRST TRANSMITTER
PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
7. Repeat steps 5 through 6 to program additional transmitters.
8. Turn ignition to OF:F position. Transmitter programming
mode will discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter
programming must be completed within time specified).
think of the top buttons from left to right as A & B and the bottom buttons from left to right as C & D. The way to turn the chime off and on is by holding the C & D Buttons simatainiously and the pressing the B button. This will allow you to turn the Hourly Chime Off and On. When you see the digital chime pattern in the display the chime is on. When no pattern is shown the chime is off. Hope this helps the ton of people who have purchased these watches & either did not have instructions with or lost them. This perticular watch has been annoying the whole household for quite sometime and has now been put to rest..lol
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
if you don't hear anything, you've turned off the hourly chime! if you hear two short beeps, you've turned on the hourly chime. turning the chime off/on is cyclic. if you press once and hear nothing, it's off. if you press again, you'll hear two beeps and the hourly chime is now on. a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off. i hope this helps someone.
Perhaps I should have mentioned that I have already looked through the online manual, which didn't help. Thanks for your speedy response anyway!
