Question about GE Refrigerators
New refridgerator ("KE" series) Istalled by technicians at 4:00 p.m. yesterday. Still not cold. All sounds as if running, lights are on, and going down the trouble shooting list, all seems good to go. What do we need to do to make this thing work?
  • 1,543 Answers
This may be a mojor problem. I have seen several refrigerators over the years which had a bad joint on the refrigerant tubing, and all the refrigerant leaked out. Try taking the back cover off and inspecting the area around the compressor. It should be nice and clean and dry. If you see any oil, that came from inside the normally sealed system. Sometimes if you turn the unit off for a while, then turn it on you might even hear some hissing of escaping gases at a leak for a minute or two. If this has not run long it can be fixed, but if it has run for a few days the unit may have sucked in a lot of moisture which can cause a premature death of a refrigerator. This is one of the few times I would advise to unplug the refrig and call for factory authorized service (rather than keeping it running until service arrives) Again, this is one of the few times (if you do indeed have a refrigerant leak) with a new unit like this I'd push the retailer or the manufactuer to replace the entire refrig instead of setteling for a repair.
Posted on Aug 31, 2008
Samsung rf267 series refridgerator not cold enougheverything else works fine its just that the milk goes off and things go bad because it doesn't get cold enough
this could be your stat has gone or you have an insulation leak gas leak you will need a fridge engineer believe me it will save you loads a call out should cost you around 25 to 30 but its cheaper then any thing else ok
Oct 22, 2012 | Refrigerators
The freezer isn't as cold as it was yesterday. Waffles are soft and ice cream is like a milkshake. The settings in the fridge at the top: Freezer--said 22 earlier. I put it on Turbo Cool and it has...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | GE Refrigerators
"HELP" HE ISTALLED NEW 3.0 LONG
year? model? what are you working on?
Dec 21, 2010 | Ford Ranger Cars & Trucks
Refridgerator and freezer are not cold
hello sir/mam
if this is the problem please check the condensor of the refrigerator for its enough refrigrant.
Sep 14, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Freezer side and Refridgerator side are not cooling food
I would find out what it would cost to fix it. If the cost is more than the price of a new one then I would get a new one.
Aug 23, 2009 | Kenmore 51562 / 51564 / 51569
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
5 year old refrigerator stopped cooling
Sounds like your refridgerant compressor or the motor driving it has bit the dust.  I am assuming it does not kick on or you can't hear it running.  Call a local appliance repair to get a quote, but 9 times out of 10, it is cheaper to replace the fridge.  A motor and compressor can cost upwards of 300-600 bucks.  That is just from my knowledge and your model may be higher or lower.  Best to get an appliance guy to take a look.
Mar 11, 2009 | Frigidaire FRT17G4B Top Freezer...
MY refrigerator is running but is not getting cold.
This has several issues you might need to look into.
First, your refridgerator you selected shows it is a front load washer. I know that can't be right.
Second. Your temp setting. It should be set in a manner that allows the humidity to exhaust out.
Third, Your refridgerator compressor is about to go out.
Fourth, you are placing alot of warm food into refridgerator, and holding the door open too long. This sometimes shuts the compressor off.
Also peer behind your refridgerator. Is there alot of debris, dirt, brooms, etc behind there. If so clear it out completely.
On the front of some refridgerators there is a grill that can be removed carefully. You will see cooling fins on the inside of this.
Very very gently remove the dirt and debris off of this. The fins bend very easily, so becareful.
At the same time check drip pan, and empty if needed.
If none of these things seem to do the trick, contact a service technician, something tells me it is your defrost sensor, or compressor.
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
