Dryers Logo
Posted on Jul 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bravos powers on but will not start, no heat or drum turning, all lights come on and worked fine last night now nothing
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Aug 12, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10843940
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Bravo 2012 gas dryer control panel
I have the same dryer. My control panel went dead today too. Light in drum works just fine. Nothing working at all on the control panel.
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
1helpful
Samsung DV210AGW/XAA Dryer, drum wont turn nor heat up
hi all, thanks for your comments. to note, it's my dryer not my washer so the suggested solutions wont work. Also, forgot to note, the unit is only 14 months old and just out of warranty. What I've done so far:
- vacuumed the filter
- striped the dryer, meaning removed top. front and small exhaust panel in the back
- vacuumed everything
- checked the belt, tight, not loose, broken or off the roles
- child safty not enguaged, toggled it anyway to be safe
- the checked micro switch next to belt by motor, not engaged
put it all back, turned on with nothing, tried every setting in auto and manual tied high to low temps and times, the time is noted, such as 40 min, but does not time down, over time, the unit sound the I'm done tone, if left as is, continues to chime then end like it did something. all along, the drum never rotated nor did it heat up.
Does one impact the other, such as if the drum does not roll then the heater wont start or vise-a-versa. Could the control panel have taken a hit or are there sensors that might have shut down to prevent the unit from starting are there fuse's that I didn't see that might have been tripped.
2answers
Key turns on but no click or start, Radio works lights work but key turns hard. No solinoid click and doesn't start.
check battery and connections first starting requires 300 plus amps lights about 50 so lights work but not enough to start try jump and if starts take to parts store and have then test battery
Kenmore electric dryer won't start
it is possible that your belt is broken open the door manually turn the drum by hand if it turns frely then the belt is broken if not it could be your door switch that has failes but normally for this problem its a broken belt
Mar 15, 2009 • Dryers
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
