Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
Stihl chainsaw settings for mixture screws
I have a stihl ms 180 that leaks bar oil all the time
Posted on Aug 11, 2009
  • 211 Answers
Hi
STIHL MS 170,MS 180 H;L;T(together)2 turns
STIHL MS 210,MS 230,MS 250,MS 260,MS 290,MS 310,MS 340,
MS 360,MS 361,MS 390,MS 440,MS 460,MS 660 H=1turn,L=1 turn,T adjust
STIHL MS 270,MS 280,H=3/4 turn,L=1 turn,T adjust
cheers savumihai71
Posted on Dec 04, 2008
Solution 1 will get you close if the saw dosn't work but Solution 2 is the final fix for all saws. Once the saw is running I fine tune it under a load. I usually set a few pieces of wood 12"dia aside for testing. I start a slice close to the end about an inch deep or just deep enough to keep to saw from jumping too badly. While cutting as much as possible without stalling and the throttle wide open I tune high mix (H). There might be some risk since I am not using both hands to hold the saw but I anticipate the worst and keep my face and body away from the plane of the saw blade. Low mix is just a balencing act between the lowest you can set mix and throttle stop and still keep the saw running without the chain moving or aid from the trigger. I've been able to turn some small saws (and others) into monsters and that's what we're after!
Posted on Mar 30, 2009
I have a Stihl ms361 chainsaw that won't give no spark. How can I fix the problem
Posted on Aug 10, 2011
  • joe b Feb 01, 2013
    check the plug and the wires going to the switch and the coil. if still no spark u need a new coil.
My 260 stihl pro is giving me trouble with a lot of oil leak. It doesn't have strength, when I try to cut with it, it just goes off.
Posted on Sep 18, 2011
  • 18 Answers
There is no set setting..you just have to adjust according to ur chainsaw..every chainsaw is different.
Posted on Sep 03, 2008
2 Suggested Answers
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Adjustment knob settings on stihl ms 362
Turn the High mixture screw out 1 1/4 turns from fully seated position.
Turn the Low muxture screw out 1 1/2 turns from fully seated position.
Make sure that your fuel mix is 50:1 and that your Air Cleaner and Spark plug are clean.
If your Stihl is still not running correctly, clean your exhaust screen and muffler thoroughly as this can cause performance issues if not clean.
Sep 08, 2014 | Garden
Stihl 015 chainsaw
Adjust the air/fuel mixture. Look at your owners manual or online because it gets a little tricky because of climate changes.
Aug 12, 2014 | Stihl Garden
Stihl MS250 overheats and burns out engine.
the carb fuel augments mite be set to lean or gas oil mixture not mixed rite
Apr 11, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
MS 310 chainsaw wont keep running
If you have a spark and compression it only leaves fueling/air problem.
to reset carb to standard settings screw both H and L screws right in. then unscrew the anticlockwise (L) 1 full turn. (H) 3/4of a turn, that should set it back to standard settings.
Oct 09, 2012 | Stihl Garden
What do you mean by LA in the chainsaw?
Locate the adjustment screws near the carburetor labeled with an "H," an "L," and an "LA." The "H" screw adjusts the high speed fuel-air mixture; the "L" screw adjusts the low speed fuel-air mixture; and the "LA" screw adjusts the idle speed.
Jan 14, 2012 | Stihl Saws
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
How do you set the mixture screws
I'd start at 1.5 turns CCW from lightly seated. Then tune for performance. It is probably fitted with tamper resistant fittings mandated by the EPA. I contact my local Stihl dealer when my saw needs adjustment. HTH
Lou
Nov 17, 2009 | Husqvarna Chain Saw 20" Bar
Tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Oct 13, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Aug 31, 2008 | Garden
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
3,664 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
