Question about Garden
STIHL CHAINSAW MIXTURE SETTINGS
HAVE A STIHL 066 MAGNUM CHAINSAW JUST WONDERING IF YOU CAN TELL ME HOW MANY TURNS THE MIXTURE SCREWS SHOULD BE SET AT
  • Anonymous Sep 12, 2008
    The high speed and low speed carburetor jets need adjustments. What is the basic starting settings? Should I bottom out the jets and back them off 1 1/2 turns to start? This saw is a 021 model.
One turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
What is the fuel oil mixture for stihl ms660 chainsaw
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 22, 2012 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 carb diagram
Don't mess with the insides of a STIHL carb, just buy a new one. Why put new parts in an old carb?
Jan 18, 2012 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 chainsaw
You are absolutely right, an 066 is a STIHL model chainsaw. Good job!
Looking for a parts diagram for a stihl 066 chainsaw
The one with the two right angle connectors is the inlet line. The other is the return line
Nov 05, 2011 | Stihl Models 064, 066, Ms640, Ms660
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
986 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
