Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Gallery Heavy Duty Front Load Dryer problem
We have a Frigidaire Gallery front load dryer which has a couple of issues- it squeals loudly sometimes continually and sometimes randomly. Also, clothes get what look like burn marks even when running on low heat or just air cycles. Any ideas as to what is wrong?
Thanks
  • 2 more comments
  • Anonymous Nov 26, 2008
    I have the same problem. It seems like clothes get stuck in the dryer (on the side with the door) and then get the "burn" marks.
  • Kathrine W
    Kathrine W Dec 28, 2008
    I have the same problem, it squeaks loud sometimes .  Sometimes not at all. Clothes and dryer sheets getting stuck. now it smells like something burned inside the dryer is blew a fuse and i am trying to get in to see the problem.  I don't know how or what i need to fix???
  • johnpschultz Feb 04, 2009
    I have the same problem with the burn marks and items getting trapped in the gap between the drum and the door. It's really starting to eat our clothes too. Someone mentioned it might be the nylon bushings, but how can I fix the problem myself? I'm very handy. Any advice? Thanks
  • Anonymous Mar 11, 2009
    Our dryer begins squealing loudly after a minute or two from being turned on.
It's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
  • Perla Garza Oct 06, 2013
    Would that expensive to repair?
Our fridgidaire gallery dryer squeals very loud for about the first 5 minutes of being on then quietly finishes it's job. It does this with each new load.
You could have a belt that is slipping on the heavy load of clothes when you first start the dryer, if so you may need to replace your belt.
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 16, 2009 | Frigidaire Dryers
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Quentin
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Apr 20, 2009 | Dryers
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Feb 21, 2009 | Frigidaire GLER341A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
2,960 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
