Question about Epson PhotoPC 3000Z Digital Camera
What should I do if the picture is blurry or out of focus?
    Master:
  • 542 Answers
Make sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode (2.3" zoomed to wide). When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. On the PhotoPC 3000z you can also use Program (Sports Mode) or Manual (Shutter Priority) to increase the shutter speed. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Posted on Sep 12, 2005
Why do I get blurry pictures on screen even when I'm focusing.
Go to MENU. Then TOOLS. Make sure Motion Detection is in AUTO.
If that is on AUTO then Put the camera on a hard surface (like tripod) and focus and see if image is still blurry. Lastly, it is difficult to focus in some conditions. Move the focus point, you can click on the screen to change it. Blur can be caused by: long exposures, camera motion during photograph, bad conditions unable to focus.
The focus routine in this camera gets confused often. It can be frustration. It will only be in focus when it is GREEN before you shoot and the camera is not shaking. At night it can take great night shots with a TRIPOD and Exposure set to -1 to -2.
Dec 07, 2014 | Nikon Coolpix S4000 Digital Camera
Picture comes out blurry
There are three main reasons for blurry pictures.
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.
Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.
Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
Feb 22, 2012 | Canon PowerShot SD870 IS Digital Camera
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
My pictures are very blurry.. We have reset to the default settings but the pictures are still coming out blurry... This was not a problem before as we have had clear pictures. What do you think the...
The auto-focus might be bad. Set to manual focus and see if that works. If not, then the focus motor is slipping or the motor itself is bad and cannot focus the lens properly.
Nov 03, 2010 | Polaroid i835 Digital Camera
Zenith Blurry Picture
i got a zenith tv and the picture is really blurry how do i focus it ?
Feb 02, 2008 | Zenith R57W46 57" Rear Projection...
Focus
The writing is more blurry than the picture. it is not that serious while shifting 1 focus wire might be loose. 2 crt base loose. 3 dust like thing near focus wire. 4 adjust focus control fitted on eht. caution it is high voltage portion do not touch unless you know about it.call tech to do it. good luck.
Sep 23, 2007 | Curtis CM19102 19" TV
Sony TV with blurry picture
blurry picture is mainly due to focusing voltage is not proper. solution 1 check & adjust focus control on flyback. 2 check crt base for loose. 3 wire going to focus control on crt base got disconnected due to foreign materials deposit on it. 4 if tv is old possibility of crt getting weak.
Sep 20, 2007 | Akai CF2791 27" TV
Out of focus
How old is the set? If picture is really very blurry, Try adjusting 'focus'. You can find this conttrol generally at the rear of the set. Otherwise,. if you know solid state electronics, Check the Focus control on the FBT. It is also possible that the CTR Base is faulty. Replacing this helps.
Mar 31, 2007 | Zenith Z25X22S 25" TV
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Epson PhotoPC 3000Z Digital Camera Logo
75 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Thomas Stauber
Thomas Stauber
Are you an Epson Camera Expert? Answer questions, earn points and help others
