Switches on Kambrook Radius fan forced heater do not stay on
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Super glue!
Posted on Sep 01, 2008
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Kambrook Urn leaking at tap
what is a Toyota, Kambrook. HUH?
URN?
tap?
what URN, what TAP. ????
kambrook heater, GAME, what?
you are on a Car forum, you know that?
Jan 31, 2014 | Toyota Cars & Trucks
The heater will run for about 45 sec. and shut down
Hi, make sure the fan is staying on before it shuts off. It sounds as though the unit is shutting off on high limit switch. For what reason I do not no. It could just be faulty. If it is a forced air as you say and the air is not as strong as it normally would be, this would cause the high limit to open. If you have a diagram or a manual on it anywhere, you can try and find this high limit switch and use a piece of electrical wire to bypass it or jump it out to see if this is the fault. They are normally located in the burner section, the probe part of it anyway. It senses the temperature of the out-put and if the fan is forcing enough heat out, and if not, off it will go. So, try and locate it and jump it out. If it continues to run then this is a safety switch and should only be left jumped out while trouble-shooting and must be replaced. If you can't find one in town, you can order one on the Internet. Check the motor also and check to see if all parts where the air flows is clean also. Get back to me and let me know what you have found and if we need to go further into it.
Sincerely,
Shastalaker7
Jan 18, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Apr 19, 2009 | Coleman Propane Forced Air Heater...
Passenger side fan stays on
If the heater blower motor resistor failed then the heater will stay on full blast to keep your window clear, for safety. If the key is turned off and the fan still blows then I suspect you have an ignition switch problem. Main power comes from the key switch to feed the heater system. The plug at the ignition switch could be melted and making contact or an internal switch problem. The switch is located on the steering column under the plastic cover.Unplubbing the switch should help diagnos the problem.
Feb 02, 2009 | 1997 Pontiac Grand Prix
Fan stays on when engine switched off
This sound is from the fuel burning heater situated in front of the left front wheel arch.It'staying on because the relay is sticking and forcing the system to work.Repair this by replacing the heater relay found solo next to the engine compartment fuse box.
Nov 23, 2008 | 2003 Land Rover Freelander
Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Feb 16, 2008 | Dayton 511 Utility Heater
Low air flow
most fan forced wall heaters do not move a lot of air. check the cfm rating on the heater. the fan sucks in air from the bottom and forces it up to the top where the element is. broan and nutone have good air flow.
Oct 23, 2007 | Fahrenheat FFH1615 Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
